is this block salvageable for boost?
Old Oct 17, 2009 | 08:52 AM
I CRX I's Avatar
Default is this block salvageable for boost?
im not sure of the history of this block but it look kind of beat up, are the damages repairable?
bottom right corner
bottom left corner
Old Oct 17, 2009 | 09:04 AM
HiProfile's Avatar
Default Re: is this block salvageable for boost?
It looks like it, as long as the sleeves have no cracks, and the mains were never overheated from a spun bearing. It should be decked so you don't have any issues with coolant leaks, or oil seepage from those crankcase tubes. I definately wouldn't run it w/o decking, since the iron sleeve tops look too corroded for a quick scotch-brite pad.
Old Oct 17, 2009 | 02:01 PM
I CRX I's Avatar
my intentions were of decking it, but would i need to fill in the aluminium where its been chipped off?? does it need to be decked flat?
Old Oct 17, 2009 | 03:19 PM
ashb82's Avatar
your machinist should be able to fix that or take the block get it welded then resurfaced. i would talk it over with who ever does your machining. if you dont have the block welded you may have to take alot off the deck surface. i would want to take as little as you have to off the deck surface.
Old Oct 17, 2009 | 03:53 PM
boosted91crx's Avatar
any one who welds aluminum can fill that in before it gets decked.
Old Oct 17, 2009 | 06:59 PM
I CRX I's Avatar
awesome, thanks guys. just one more question though, am i looking at allot for the repair? i basically got it for dirt cheap.
Old Oct 18, 2009 | 10:26 AM
ashb82's Avatar
i had a block like that costed like 15$ extra to get it welded.
DA9tothewheel
Engine Machining & Assembly
Aug 21, 2016 02:48 AM
EDLOVA23
Aug 3, 2010 11:50 AM
Glove
Jan 23, 2010 12:04 AM
Pengo
Jun 8, 2004 05:31 PM
bluedelsol
Jul 10, 2003 02:56 PM
