is there something wrong with my valves?
Old Oct 9, 2009 | 05:21 PM
I CRX I's Avatar
Default is there something wrong with my valves?
so i took my JRSC off today and took a gander down my #4 runner and i see this
theres a small gap as if they didnt seat right...is the normal? all other 3 cylinders look fine, heres a pick of #1 valves
the car ran like crap but i figured it was a fuel pump problem...
Old Oct 9, 2009 | 05:47 PM
runsfromdacops's Avatar
Default Re: is there something wrong with my valves?
bent valves. take the head off set it on the valve cover and pour some alcohol in the combustion chamber. if it comes out any of the runners then the valves are bent.
Old Oct 9, 2009 | 06:23 PM
slow96lude's Avatar
well lets see. It could be that you cam just happen to be on the intake stroke on that cylinder. Your valves aren't bent.
Old Oct 9, 2009 | 06:31 PM
NonovUrbizniz's Avatar
Loved
You don't think he should maybe try a leakdown test before he pulls the head???
As mentioned above that cylinder may be in the intake stroke and nothing is wrong.
Chances are you shouldn't be diagnosing your problems.
Who built/tuned the car.
Old Oct 9, 2009 | 08:38 PM
I CRX I's Avatar
well i honestly i dont think i ruined anything but what would be some symptoms of bent valves? would i hear anything unusual coming from the motor? and smoke? i thought if the #4 valves opened, the # 1 valves would be open also...am i and idiot for thinking this?
Old Oct 10, 2009 | 01:16 AM
david974's Avatar
Once i had a bend valve on a friend car, symptom very bad idle, and that's all the car seems to work normaly with just stumbling idle
if really bend do a compression test and you 'll see it
Old Oct 10, 2009 | 05:18 AM
mikeymcm's Avatar
i doubt they're bent , why dont you turn the crank with a ratchet and see if they close.
Old Oct 10, 2009 | 09:05 AM
HiProfile's Avatar
Exactly, turn if over 360* (couter clockwise, slowly; mark bolt and pulley so it doens't move). Otherwise pull off the valve cover and look at the cam lobes. If they are "sideways", pointing to the front or rear of the car, they're probably just opening or just closing.
If the valve is bent that bad, it probably would have snapped by now. And since the JRSC runners are so short, it would lead to a noticable power loss, with exhaust gasses being pushed into other cylinders.
menfou
Honda S2000
May 17, 2011 05:48 AM
HondaKing90
19
Feb 15, 2010 04:38 PM
civicmitch
Apr 27, 2009 02:07 PM
junkyard racer
Sep 7, 2008 04:41 PM
