pushing coolant under boost!!!!
Old Oct 18, 2009 | 05:15 PM
shady1375's Avatar
Default pushing coolant under boost!!!!
ok so i oringed the head with a copper gasket...... i was told it was a head gastket problem. we put it back together and the same thing.... only under boost. i was told to retighten the studs because the head was lifting. i was also told to check the thermostat and the radiator cap...... any suggestions? before i put this new head gasket on you could smell the exhaust in the overflow. now you cant!!!!! im lost. please help
Old Oct 18, 2009 | 05:28 PM
Urban_Indian's Avatar
Default Re: pushing coolant under boost!!!!
if the head & block decked?
and how tight are you putting the head down, what gasket etc etc etc
Old Oct 18, 2009 | 05:37 PM
shady1375's Avatar
yep the head and block were decked!!!! its a sce copper gasket. i have arp head studs and we tightened them to spec..... does that help at all?
Old Oct 18, 2009 | 05:38 PM
shady1375's Avatar
i have hondata intake gasket, the block is sleeved, the head is built..... it wont do it under normal driving but the second i hit boost it does it......
Old Oct 18, 2009 | 05:39 PM
shady1375's Avatar
sorry the motor is an h22
Old Oct 18, 2009 | 06:27 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
you have air coming into the system somewhere. since you've changed the headgasket go ahead and try the radiator cap. why aren't you using a OE headgasket?
Old Oct 19, 2009 | 01:46 AM
shady1375's Avatar
We were using honda gaskets and it blew under high boost..... so that's when I took off the head and had it oringed....... radiator cap is my last choice..... anymore ideas??????
Old Oct 19, 2009 | 04:53 AM
boosted k20's Avatar
what ft-lb did you torque it too? if 65 ft-lbs, try 80 ft-lbs.
Old Oct 19, 2009 | 05:47 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
you o-ringed the head or the deck
flozella
Aug 30, 2014 07:20 PM
hamizle
Dec 1, 2009 04:55 PM
integraturbo
Oct 29, 2008 10:56 AM
hawaii_boi_808
Jun 20, 2008 09:17 PM
Lei Siew Long
May 30, 2002 03:32 PM
