Methanol on a B Series?
Old Oct 2, 2009 | 02:18 PM
mofia77's Avatar
Default Methanol on a B Series?
Contemplating using an AEM meth kit on my setup. I'm coming from the evo world where this is fairly common. Any of you guys using methanol with your setups?
If so, please post specs, whp figures and a dyno sheet if possible.
If not, why don't you?
Old Oct 2, 2009 | 02:34 PM
rev-speed's Avatar
Default Re: Methanol on a B Series?
R u looking to same money on race gas or make power?
Aem meth kit is junk has start up leak problems and idle leak problems
Old Oct 2, 2009 | 05:22 PM
mofia77's Avatar
More as a failsafe against a bad tank of gas and to perhaps run a few more psi of boost as a result with peace of mind. I'd consider another meth kit, I'm just interested to see some pump + meth setups and the results.
Old Oct 2, 2009 | 05:50 PM
E85B18's Avatar
A lot of people are running meth kits with 91/93 octane for more boost. An EVO is no different. Why dont you just run E85? Problem Solved!
Old Oct 2, 2009 | 06:11 PM
mofia77's Avatar
I'm not in the US, and it's not readily available here.
Old Oct 3, 2009 | 07:33 AM
HamiltonRex's Avatar
You from Canada?
I run the AEM water/meth kit on my dsm, I know this is no help to you because your asking about using it on a Honda, but its no different. I like to make lots of power on pump gas so when I drive on the street in not burning away my wallet using C16, so I use meth injection. FWD can't hook up with street tires on the power you make on straight pump anyways.. so they don't always 'want' to make that much more, except when there at the track and are set up to go fast, than they just use the race gas.
Goodluck.
Old Oct 3, 2009 | 09:05 AM
E85B18's Avatar
Rex has a good point. I couldn't get traction on my 91 octane tune and that was without meth. I had 430whp. Until you fix your traction issue, more power is not always the best thing.
terbear4god
Jan 25, 2012 07:33 PM
boostedb20z
Aug 14, 2009 09:13 AM
Topdawgg
Nov 5, 2008 05:51 PM
Poey2
Jul 31, 2008 11:01 PM
iBrandon
Aug 3, 2007 08:30 AM
