Engine building guru's... Need your advice.
Old Oct 17, 2009 | 06:22 PM
jbell's Avatar
Default Engine building guru's... Need your advice.
Here's the deal.
I have a rotrex supercharger, it's a C30-94. I understand all the math about pulley sizing and such, and how to get the most out of the blower, without over-spinning it.
That's the easy part.
The hard part is figuring out what block I want to Frankenstein this supercharger onto.
It's designed for engine sizes 2.0 and up.
I've seen it used on a build type-r block (b18c6), 9.8:1 81.5mm pistons, eagle rods, arp headstuds, put down just shy of 290hp.
I'd love to make more power than that. Since I'm working at the limit of the blower, at 10psi or so- I figure 1 of 2 things has to happen:
1- Higher Compression
2- Bigger Displacement
What is the most reliable way to get more displacement?
Assuming I have a b16 head... should I go straight for the b20 block, or go with the gsr and stroke it, or what-
I have no idea what to do.
Anyone care to offer advice?
Old Oct 17, 2009 | 06:46 PM
NonovUrbizniz's Avatar
Loved
Default Re: Engine building guru's... Need your advice.
I don't know enough about the actual rod/stroke ratios of the various bottom ends... but you'd definately be better off with more displacement then higher compression... unless you have some method of heat reduction to the intake/charge air. Meth injection or a very efficient after cooler... high compression and s/c and high rpm can be a pretty ugly combination.
I'm no expert though so lets see what some others have to say.
Old Oct 17, 2009 | 10:13 PM
Muckman's Avatar
Moderator in Chief
Even if you bore and stroke it to 2.0L you wont gain that much. Look into water/meth injection or possibly nitrous
Old Oct 18, 2009 | 01:36 PM
2004es2's Avatar
They make a 2.2 stroker kit for the type r motor, wouldn't be a good daily though.
Old Oct 18, 2009 | 01:46 PM
Hammerin's Avatar
New User
"I've seen it used on a build type-r block (b18c6), 9.8:1 81.5mm pistons, eagle rods, arp headstuds, put down just shy of 290hp."
Is this your current setup?
This setup should see about 340-360hp, the cause is probably bad tuning and and high restriction in the exhaustpipe, ther is possible high inlet temp due to bad intercooling.
Put in nasty cams and tuned cametiming and you will easy brake 400hp.
Old Oct 18, 2009 | 10:32 PM
civic_r87111's Avatar
To do a 2.2L stroker u would have to bore it and get a block extention to stroke it that 95mm. Also to get it a 2.0L u would have to bore it to 84mm so then u should really sleeve it. I would bore it to 82.5mm and stroke it to 89mm and call it good.
lukerc45
Jan 23, 2024 12:34 PM
Andre
Feb 9, 2007 06:00 PM
Samuels
Jan 6, 2007 09:04 AM
matman4444
Jun 12, 2004 03:35 PM
vtec94civic
13
Feb 6, 2004 09:50 AM
