Post-boost problems
Old Oct 4, 2009 | 10:07 PM
Kensai's Avatar
Default Post-boost problems
So I just took my turbo off and I'm having some problems. The motor is burning oil, its most likely bad piston rings. It is a sleeved motor so someone told me it might be a shifted sleeve? What is the probability of that? I'm going to take the motor apart, what should I be expecting? Can I just replace the pistons and the piston rings or will any machine work need to be done to the cylinders? Thanks in advance...
Old Oct 5, 2009 | 12:21 PM
accord_raffi's Avatar
Default Re: Post-boost problems
what makes you think it's the rings?
Old Oct 5, 2009 | 12:41 PM
Kensai's Avatar
What else could it be?
Old Oct 5, 2009 | 12:56 PM
TheShodan's Avatar
Moderator
Could be bad valve stem seals or valve seats in the head. You may want to perform a compression and leakdown test first before making the determination that is the piston rings and wind up getting the wrong parts that are not necessary
Old Oct 5, 2009 | 01:02 PM
Kensai's Avatar
We changed all of those and had the head checked when we had to replace the headgasket about 2 months ago.
Old Oct 5, 2009 | 01:07 PM
PCV could do it too. Hell, it might be your turbo.
Old Oct 5, 2009 | 01:57 PM
Kensai's Avatar
I never heard of oil burning because of bad PCV valve, nevertheless it was checked as well. The turbo is off the car like I said, the only reason I took it off is because I thought it had bad seals but it still burns oil even with the turbo off...
Old Oct 5, 2009 | 07:27 PM
Search google if you don't believe me.
Old Oct 6, 2009 | 01:28 AM
Kensai's Avatar
Anyways...assuming it is the piston rings...
Old Oct 6, 2009 | 07:10 AM
If it is rings, you'll have to hone the cylinders to get a proper seal with the new rings...I'm 95% sure you do anyway.
Old Oct 6, 2009 | 01:55 PM
Kensai's Avatar
Gotcha, thanks!
acman1
Jul 27, 2007 04:20 AM
premo_si
Mar 5, 2006 08:31 AM
hondaapi
Apr 28, 2005 10:09 AM
EKtypeRhaTcH
26
Feb 21, 2005 09:23 AM
bboyoxygen
11
Nov 2, 2004 09:55 PM
