ID 2000s made by Bosch?
Old Oct 7, 2009 | 06:43 PM
turbociv910's Avatar
Default ID 2000s made by Bosch?
Is this true?
ID scratches off the Bosch part number?
All they do is make the caps from the 48mm to 60mm injector height?
correct me if i heard wrong, just looking for answers.
Old Oct 7, 2009 | 06:53 PM
HamiltonRex's Avatar
Default Re: ID 2000s made by Bosch?
wouldn't suprise me.
Old Oct 7, 2009 | 06:54 PM
93turbo16's Avatar
Yes, they do start with Bosch injectors.
Read up, it will tell you all you want to know.
http://injectordynamics.com/
Old Oct 7, 2009 | 07:34 PM
archull's Avatar
they are modified bosch injectors, not stock bosch injectors. They start off as OEM injectors for stock vehichle and they are modified for increased flow. ID is not the only company that does this yet they are the most expensive. If you want the same injectors for a fraction of the price get in touch with these guys
http://fuelinjectorconnection.com/shop/index.php
Old Oct 7, 2009 | 07:58 PM
good info on that site.
I was ill informed then, I was told there is a new bosch part number for a 1890cc injector, then ID buys them and calls them 2000s with their caps on them to fit b series.
Anyone want to trade for FIC 1850s?
Old Oct 7, 2009 | 08:01 PM
mtber's Avatar
I have personally tuned a car on these injectors. All I can say is WOW.
These things blow any 1600cc low impedance injector I have used away!
Old Oct 7, 2009 | 08:14 PM
Ovrbst_T66's Avatar
Same here tuned a freinds car with a set of these injectors on e98.Car runs smooth at idle and under cruise you cant even tell the difference between these and stockers.
Old Oct 7, 2009 | 08:33 PM
archull's Avatar
I am just currious of what the hell you were tunning that required this much fuel
Pics of setup, lol
Old Oct 7, 2009 | 09:51 PM
jdm inc's Avatar
heres a vid of T1 testing them on a stock motor. idle like Stock!
http://www.youtube.com/watch?v=RX1xIvOWcNk
Old Oct 8, 2009 | 07:24 AM
twkdCD595's Avatar
http://www.injectordynamics.com/garbage.html
Yea I think there was some pictures of some knock off ID1000's being seen around... the above link describes what you get with wonderful low cost attempts to copy ID's quality machining and matched flow injectors.
Dont know if whatever injectors from FIC your talking about are truely an equal or just another underperforming knockoff, but personally I will stick with the real deal originals. They have been proven over/ over agian and have the backing of many very well respected tuners/ customers/ shops for a reason. I would rather spend a few extra bucks on such critical parts sometimes to get best quality product/ customer service than compromise with something I am less sure of.
Edit: Looked all over the FIC site and I dont see any modified Bosch's that are on par or anything like the ID1000 and ID2000 modified units.
Old Oct 8, 2009 | 11:33 AM
96 GSR-T's Avatar
Anybody run the new 2000's yet? I was wondering if they can hold an idle leaner than 12.0 like what was shown on T1's vid. (I know thats asking alot...lol)
Old Oct 8, 2009 | 11:44 AM
93turbo16's Avatar
I sold a set to a friend that has them on his built Eclipse GSX. It is running E85 and claims it idles perfectly fine at a ratio in the 14s and part throttle/startup are 100 x's better than his old Precision 1600cc injectors.
Old Oct 8, 2009 | 01:26 PM
srmofo's Avatar
Someone should put the generics up against the IDs in the same car. Something similar to the little test done on the stock integra. I would but I dont have the dyno or the knowledge to tune. And I think if tony1 did it people still would not believe the difference. So someone else that doesnt sell either product would have to step up. So many skeptics out there. But I think that would finally put this subject to bed.....
or ****'em, let the skeptics learn the hard way.
Old Oct 8, 2009 | 02:04 PM
ShortbusEK's Avatar
i havnt looked in a few weeks.. but where can i buy them at? i want them! 720's gotta go with the 35r!
Old Oct 8, 2009 | 02:07 PM
ShortbusEK's Avatar
i dont remember who it was.. probably t-1.. put up a dyno vid on HT not too long ago (search for it) with them on a bone stock LS motor i think it was.. thing idles ALMOST like stock.. even made more power without retuning (just scaled stock maps for the injector size) because of better fuel atomization!
Old Oct 8, 2009 | 02:28 PM
jdm inc's Avatar
thats the vid i posted above he did a a test on a bone stock ls and it idle like stock!
Old Oct 8, 2009 | 02:32 PM
96 GSR-T's Avatar
Thanks John, I was hoping E85 would run well with them... I think I am going to fork out the cash for these
12.0 AFR is not idleing like stock, they were smooth though.
Old Oct 8, 2009 | 07:10 PM
Turbo-charged's Avatar
i have done a back to back test, on 2 different engines (one roller non/vtec cam, one vtec style camshaft) and there is a huge difference. the biggest difference is in the battery offset information. kick the rad fan on with the knock offs and watch afr go from 14.0 to 12.0 and the idle stumble..... not with the ID's.
the people who are interested in the knock offs dont care what the test results are for the most part. the people who want the good parts, the first time, are going to go with the ID's right from the get go. i did the test for my own personal knowledge to see if they were all they were hyped up to be.
a lot of people push shitty products on this site to try to make money, so i'll question anything and everything. (99 out of 100 times the shitty parts have better profit margin than the good ones)
the ID injector line up is the real deal. will be using a set of 2k's on a car hopefully in the next week or so. pulling out a set of 160's. im 100% confident its going to be a night and day difference.
Old Oct 8, 2009 | 07:29 PM
srmofo's Avatar
I had a set of precisions 780s and before this engine is completed I already bought a set of the id1000s to replace them.(the precisions are for sale btw) I read all IDs info and it all came from very crdible sources. Im just waiting till I get other things in order and Ill be testing them first hand.
Ive seen the stock integra video already I just wanted to see what the cheaper modified boschs would do in the same engine. Im really curious what 1600cc sound like in a stock engine.
Old Oct 9, 2009 | 05:27 AM
96 GSR-T's Avatar
They sound, idle and run like ****, if you drive your car on the street 1600's are teh gayness...
Old Oct 9, 2009 | 12:57 PM
ShortbusEK's Avatar
holy cow they are $250 a piece! i knew they would be high but $1k for injectors... looks like ethanol will have to wait til next year!
Old Oct 9, 2009 | 01:43 PM
HRTuning's Avatar
Originally Posted by twkdCD595
Hmmmm. "Idiot" this. "Idiot" that. They're completely right about the other product not being good quality, but I don't think it's good practice for any business to call someone an "Idiot" in plain sight regardless of whether the other person/company produces an inferior product, is in direct competition with them, or posted ill about them in public.
I'll still recommend the injectors because they are EXCELLENT and my hat's off to the amount of effort ID puts into their products, but I've just lost a little bit of respect for them as a business entity. It's sad that I had to consider that they might see this post and start calling me an "Idiot". That page could have been handled much more maturely, even if he went back at a later date to change it.
Old Oct 9, 2009 | 01:58 PM
tony1's Avatar
While the post may seem a bit harsh at this point, it was preceeded by many claims of us being full of **** and overpriced and that people were only paying for a name. Might not justify things, but at least some insight as to where the frustration was coming from at that point.
Old Oct 9, 2009 | 02:06 PM
HRTuning's Avatar
Oh I definitely know where it came from, I followed up before I posted and I actually remember some of the posts calling you out. I'm glad he labeled it as a rant at least. When I research a company I look at stuff like this and that's basically all I'm trying to say here. It's just my opinion of how it can be taken.
You guys definitely beat the competition hands down. I've seen these injectors in person and they are top notch quality. They perform as advertised and I'll definitely recommend them to everyone who's looking. Keep up the good work!
Old Oct 10, 2009 | 07:50 AM
Ovrbst_T66's Avatar
Here is a vid of my freinds car with the new id2000 under highway speeds,at idle the leanest we got it was 13.0 on .80ms anything leaner its hard to control.We made 650whp 25psi duty was at 25% on e98 we stopped there cause of ignition problems.Video is a little shaky,our highways suck.
http://www.youtube.com/watch?v=CmdC2TVQBMY
http://www.youtube.com/watch?v=-xn-c...eature=channel
