Pistion Advise PICS And Spec.
I have a set of pistions im thinking of buying off a friend of mine and whated to know what u guys think?
I have a d16z6 they are for a b16a3 can i make them fit with some sleeves or something else or do i need a b16 to buy,
and how much are they worth they are brand new.
Re: Pistion Advise PICS And Spec.
ok thanks but theres no way i can make them fit with sleeves or anything, guess not
they are for sale then in market place. lol
has anyone put anykind of other pistions in d16z6 like other car makers then vitria like some krazy ones?? in a sleeved motor or bore or something??
thanks all
thanks all
thanks all
thanks all
If you want to do a d-series then run vitara pistons. why are you trying to put crap in motors that one fit?
you can shave it down with scissors... my buddy just put some mark 2 vw rods in his b20vtak ...
it hits vtak so hard at like 2500 rpm... bam!
no.. you can't do it..
stock bore d series = 75mm
stock b= 81 mm...
stock b= 81 mm...
It's not the piston that makes power in a turbo motor - it only allows you to create more power with more boost pressure.
Those pistons are probably in the $350-450 range. They are 84.0mm bore size, which is either for a sleeved/bored B18, or a B20 block. Not very popular. BTW on the tag in the picture, what does it say to the right of "INV DOME VOLUME"? I'm guessing around -10cc to -15cc, which would be ~9:0 compression.
d16z6305civic
14
12-29-2010 01:24 PM
illogic65
11-16-2004 11:38 AM
