Omni 4bar map instructions?
Old Oct 15, 2009 | 05:31 PM
Black93si's Avatar
Default Omni 4bar map instructions?
Does anyone have a wiring diagram for a 0mni 4bar map sensor for 92 civic?
I bought a hatch from a hack **** and he ran the map sensor wires directly to the ecu and one of the wires came loose.
Thank you
Old Oct 15, 2009 | 05:40 PM
93turbo16's Avatar
Default Re: Omni 4bar map instructions?
Thank you
It is exactly the same as an OEM map sensor.. check out the helms manual.
Old Oct 15, 2009 | 06:17 PM
mtber's Avatar
green = ground
white = signal
yellow = voltage (5 volts)
Same as factory....
Old Oct 15, 2009 | 07:23 PM
Black93si's Avatar
Thanks for the replies... He has 3 red wires going to it...fixed it though
JasonHi
17
Jun 18, 2020 06:34 PM
ENJOI
11
Aug 23, 2006 10:39 AM
nick-vti
Aug 10, 2004 09:27 PM
