what size turbo for ac and power steering?
I got a b20V in my eg hatch and Im wondering what size turbo should I run with ac and power steering? Im trying to make only 300hp to 400hp daily on 91.
Re: what size turbo for ac and power steering?
there are quite a bit of a/c compatable turbo kits out there.
i suggest t3 t4 57trim for your power goals, made 385whp@16psi on my friends stock gsr
Moderator
It depends upon which compressor / exhaust size the manifold accounted for. be it a 50,57,60, 61mm, or 60-1 wheels themselves are not relevant, only the compressor housing and turbine housing are the most important. Most of the time it is the 7" (I believe) "E" cover that can be used. But it depends upon the manifold that you're using and what the fabricator designed it with.
shermanyang
03-19-2003 07:13 PM
