fluidamper vs. ATI
Old Oct 15, 2009 | 01:41 PM
kmaz93da's Avatar
Default fluidamper vs. ATI
debating if i need an aftermarked crank damper for turbo gsr 450-500hp rev limiter 9300.....any difference between fluidamper and ati? fluid vs elastomer
and between street and race version?/aluminum vs steel...... not using powersteering/ac too
Old Oct 15, 2009 | 02:31 PM
non-VTEC's Avatar
Default Re: fluidamper vs. ATI
i can't comment on the ATI unit but i am running a fluidampr steet pulley. no issues. very smooth/balanced above 6000+rpm.
srteet versions have the ribs and grooves for ac and ps belts. the race versions have those cut off so it only drives the alternator. the race versions will be a little lighter because of that.
is an aftermarket balancer "required"......not really.......but when you have a few thousand bucks flying around 8000+ rpm its better to be safe than sorry.
Old Oct 15, 2009 | 02:43 PM
jnv255's Avatar
if i was to get one, it would be the ATI
Old Oct 15, 2009 | 03:06 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
I have ATI street
here is the diff besides the obvious. (the extra pullies)
for a street car you want to get the street version, you ask why? becuase the altenator pulley isnt underdiven like the race version. the race version damper actually affects your voltage output to your alternator a lot of people who have the race pulley run an upgraded alternator. Not all but some. To back this up a buddy had the race ati on his car and he has a Bosch044 inline with walbro. His voltage fluctuated around 12volts when it should have been at 13.5 easily. Which effected his fuel pressure
Old Oct 15, 2009 | 04:07 PM
Turbo-LS's Avatar
Fluidamper works better in lower rpms and quicker and uses a viscus fluid to dampen engine harmonics while as the ati is an elastometric dampener and uses rubber to dampen engine harmoncs liek the stock unit but way better and the ati performs better the higher you rev. Both are tried and true pieces but IMO ati ftw and yeah get the street version.
Old Oct 15, 2009 | 04:08 PM
Tony the Tiger's Avatar
I have the Fluidampr street, but the race version (Fluidampr Race) uses the same factory alternator belt and is not underdriven. The ATI is different as mentioned by HybridLST above.
Old Oct 17, 2009 | 06:59 AM
Turbo-LS's Avatar
Tony how does that do in Toronto with the cold weather? I've read the fluid freezes and causes failure with the balancers
Old Oct 17, 2009 | 07:41 AM
non-VTEC's Avatar
not true...i inquired to fluidampr about that a couple years ago. the stuff inside is resistant to freezing. i DD mine in the freezing cold last winter and will be again this winter. no issues then and im expecting no issues now.
Old Oct 17, 2009 | 05:11 PM
It's supposed to have a freezing point of -50C or something like that.. I've asked their tech support before I purchased it about 4 years ago, and mine is still doing great. I guess don't park your car inside a meat refridgerator...lol
Old Oct 17, 2009 | 06:24 PM
purpleh22's Avatar
Try looking up 'fluidamper test' on the internet. I remember seeing test results that said the elastomer hardened after use and running on the engine with repeated warmups. When cut open later, it had solidified????
Old Oct 17, 2009 | 08:25 PM
grndcont's Avatar
they just recently put out an ad for the fluidamper saying that the guts are gel from the factory, not liquid. lots of roumors about it solidifing.
Old Oct 19, 2009 | 12:53 AM
It's supposed to be a gel... Summitracing had always listed them as a silicon gel from the very beginning, but the import guys didn't really know about it.
What's important is whether it works well or not.. You can't go wrong with either one, and knowing that my oil pump gear is still in one piece tells me its working...lol
Old Oct 19, 2009 | 05:27 AM
hondaapi's Avatar
Is there a point when you can say a damper like the Fluidine or ATI is needed?
Old Oct 19, 2009 | 05:58 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
i would say when your pushing the RPM's up and you have a blue printed balanced motor.
Old Oct 19, 2009 | 07:44 AM
Turbo-LS's Avatar
Stock pulley only does so much, it "works" but not the best. If you can afford one even on a daily driver and your boosting and making nice power then IMO its a good thing to have especially over a stock unit that barely has any rubber in it to absorb harmonics
Old Oct 19, 2009 | 12:32 PM
kte324's Avatar
So, the alt pulley on the race fluidampr is not underdriven?
Old Oct 19, 2009 | 02:43 PM
kmaz93da's Avatar
so I dont want the underdriven pully since its a street car, so i I either buy the ati street or the fluid street/race then what should i get BETWEEN STEEL and Aluminum hubs?
Old Nov 23, 2009 | 04:13 PM
gsp ej1-em1's Avatar
so whats better? ati or fluidampr? I'm still debating also.
Old Nov 23, 2009 | 04:50 PM
cjordan's Avatar
ATI here and I love it. I dont think your going to get a straight one is better than the other answer, just personal experiences. Def worth getting just for the added peace of mind for the bottom end.
Old Nov 23, 2009 | 05:21 PM
If i got the race one. what alternator belt would i run?
Old Nov 23, 2009 | 06:17 PM
cjordan's Avatar
I run a regular ol advance auto parts alternator belt on mine
Old Nov 23, 2009 | 06:57 PM
redboost10's Avatar
call any aftermarket crank/piston/rod company and they will recommend you use ati....eagle, lunati, isky, crane, etc.
Old Nov 24, 2009 | 08:27 AM
sweetfwdthunder's Avatar
ATI ftw
Old Nov 25, 2009 | 01:28 PM
mcclure's Avatar
ATI here works great
Old Nov 25, 2009 | 05:59 PM
HiProfile's Avatar
You guys have to remember the stocker is intended for a heavy flywheel, power steering, and usually A/C. The extra mass & accessories tends to help with harmonics. It was also not intended to be ran after it starts cracking & seperating. Most original dampeners I've seen are already cracking...
Couldn't have said it better myself.
