H22 Dyno results sub par
Old 10-14-2009, 05:29 PM
Varano44's Avatar
Default H22 Dyno results sub par
I posted this in the Prelude section and decided to move here for more input on my situation. I got the dyno results today and it showed 8psi 290hp and 18psi 385hp. This is my setup.
JE 9:1 pistons
eagle rods
iron ductile sleeved block
micro polished crank
port & polished head
ferrea valves, springs, retainers
wiesco head gasket
holset hx35
walbro 255
3 in exhaust
tial wategate, blow off valve
1000cc injectors
stock intake manifold
tuned on crome
skunk2 turbo cams
ramhorn exhaust manifold
I just feel that 18psi is a ton of boost to only be at 385hp. What are your opinons?
Old 10-14-2009, 05:51 PM
TopEndUSA's Avatar
Default Re: H22 Dyno results sub par
Try playing with the timing degrees. From help of HT members we found that our car wanted more timing and it really woke up. at 20psi on 93 octane it made 497whp.
Old 10-14-2009, 05:52 PM
N.Y.C.E.'s Avatar
nice set up should make 450whp with ease!
Old 10-14-2009, 05:57 PM
boosted91crx's Avatar
that does sound low for that turbo and that size motor. but regardless i bet its fun to drive and fast as heck.
Old 10-14-2009, 05:58 PM
Varano44's Avatar
My tuner gave me the results today and tomorrow I'm going to pick it up, any sugestions on what I should do?
Old 10-14-2009, 06:08 PM
B20luda's Avatar
Go back to stock cams
Maybe have another tuner check it out
Let's see the graph
Old 10-14-2009, 06:22 PM
turbociv910's Avatar
Post a graph, we can evaluate it much better
Old 10-14-2009, 07:27 PM
digdug18's Avatar
Hows the torque as well? Try a different tuner. Your tuner, if he's good, should be able to tell you whats wrong and tune it for you.
Old 10-14-2009, 08:14 PM
Jimster480's Avatar
you should not tune on chrome. All that money in the setup and ur running chrome? Go on eCtune or Neptune. I'm tuned on eCtune and my car makes good power for its boost.
Old 10-14-2009, 09:01 PM
Varano44's Avatar
Thanks for all the advice, tomorrow after I talk to the tuner and check it out, I'll post his suggestions and the graph.
Old 10-14-2009, 09:02 PM
jnv255's Avatar
you might have to much of a cam for that turbo, dont know, need to see your sheet... ill try and help out a fellow Grunt, 11B forever...
Old 10-14-2009, 09:09 PM
ProjectBB6's Avatar
stock cams!
Old 10-14-2009, 11:31 PM
DC4KiD's Avatar
LOL!
:facepalm:
Old 10-15-2009, 04:57 AM
Jimster480's Avatar
Originally Posted by DC4KiD
LOL!
:facepalm:
no. Chrome is pretty ****.
Old 10-16-2009, 11:54 AM
JDM H2B EK's Avatar
yea man its definetly those turbo cams THEY SUCK i had them in my stock h22 tuned by jeff evans at evans tuning and it only made 280 on 8psi so i replaced with stock obd1 jdm h22 cams it it made 345whp nothing changed but the cams so i got 60 more whp and i wrote to skunk to and everything and they said" these cams were designed for more of a bolt on turbo kit liek greddy or drag" i was pissed they still cost 600$ and clearly states good for street cars and low boost seetings work best from 5 to 15 psi and optimal for 3-8500 rpm
Old 10-16-2009, 11:55 AM
JDM H2B EK's Avatar
yea lil and chrome sucks 2..... get s300 lol
Old 10-16-2009, 11:56 AM
JDM H2B EK's Avatar
those cams have lower duration than stock
Old 10-16-2009, 12:04 PM
ESP.net's Avatar
Ectune or Hondata ask Skunk2 what they recommend cam gears to be set at with Turbo 2 cams, that could be a big deal in power
Yes 18 psi and 385 hp don't mix... made 411 hp with 15 psi on 50 trim T3/T4 H23V
385 hp should be 10-12 psi?
Old 10-16-2009, 12:07 PM
JDM H2B EK's Avatar
tel him john lol... well jeff evans is a dealer for skunk2 so when this happened he called him and even then they told him those cams suck and the only reason they sell them is cuz people buy them and they offered me a discount on different cams .. so when i went to purchase a different cam i asked how much of a discount i would get they have not responded yet and its been since march
Old 10-17-2009, 12:58 AM
808speedSyndicate's Avatar
use the h22 or f20b type-S cams, a little better then the stock h22 cams..
sohctodohc
06-10-2021 03:42 AM
sohctodohc
12-12-2020 09:10 AM
98vtec
01-11-2014 10:32 AM
ParrisEngineDynamics
184
05-17-2010 09:56 AM
Varano44
10-16-2009 07:36 AM
Quick Reply: H22 Dyno results sub par
