car is running hot
Old Oct 14, 2009 | 09:14 AM
chrisfromsrq's Avatar
Default car is running hot
just put a gt28rs on my b20 running 8lbs. in the city the car is fine. when i get on the interstate the temperature jumps up. id say to about 3/4 the way up. could this be caused by using a stock radiator? how can i fix this problem? run a oil cooler? need help. i dont want to overheat my engine
Old Oct 14, 2009 | 11:32 AM
DA TeG 90's Avatar
Default Re: car is running hot
Welcome to owning a boosted honda. Get a mishmonto (how ever you spell it) and a thermistat. That should help. Get a slim fan while your at it.
Old Oct 14, 2009 | 11:37 AM
i got a slim fan. ill look into the radiator and thermistat thanks
Old Oct 14, 2009 | 11:51 AM
boostedEF91's Avatar
shouldnt really be the radiator. i mean every stock honda out there is cooled by a stock radiator. maybe head warp. try some headstuds. do you have enough coolant in radiator.? new thermo could help.
Old Oct 14, 2009 | 11:52 AM
dpetro1's Avatar
Originally Posted by DA TeG 90
Get a SPAL 13" fan while your at it.
fixed it.
OP, make sure the coolant is bled properly. Radiator upgrade and a good fan with shroud will probably take care of your issues. The intercooler blocks airflow and causes the overheating. Pull the bumper off, if that cures the problem then you know you have an airflow issue
bigchris2000
14
Aug 6, 2010 08:25 PM
kr3wwwww
May 18, 2009 09:00 PM
fudo1252
Feb 12, 2008 01:55 PM
JDM_Silver
May 30, 2007 09:03 AM
TC21
May 9, 2006 11:19 AM
