.120" head gasket question.
Old Oct 15, 2009 | 02:09 PM
EG6 Love's Avatar
Default .120" head gasket question.
i have a fully built gsr block and head. building it for ~450whp.
the block has been cut 1 time.
the head has been cut 2 times.
i dont know how much was machined off... so...
IS A .120" HEADGASKET A GOOD IDEA TO USE IN ORDER TO BEST RESTORE LOST CLEARANCE BETWEEN THE PISTONS AND VALVES?
WHAT IS THE EFFECT ON MY COMPRESSION RATIO?
LETS GET SOME OPINIONS ON BRAND NAMES TOO!!
Old Oct 15, 2009 | 04:13 PM
Muckman's Avatar
Moderator in Chief
Default Re: .120" head gasket question.
Without knowing how much was milled off you're just guessing.
If your pistons are still below the deck there wont be any interference with valves.
Im in the same position. I just run oem, its fine.
Old Oct 15, 2009 | 04:54 PM
EG6 Love's Avatar
i take it a gsr IS NOT an interference motor?
WHAT ABOUT MY COMPRESSION RATIO? I USED A COMPRESSION CALCULATOR AND A .120" VS. A .74" HAD A COMPRESSION RATIO OF ~9.0 VS ~10.0.
Old Oct 15, 2009 | 06:03 PM
EG6 Love's Avatar
bump
Old Oct 15, 2009 | 06:55 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
You are making Indiana look like it’s full of a bunch of idiots... ALL HONDA MOTORS ARE INTERFERENCE ENGINES!!!
Old Oct 15, 2009 | 07:22 PM
HiProfile's Avatar
Muckman meant that the piston shouldn't interfere with normal valve movements. Unless you have a crazy high-lift cam, there should be enough room.
However I'd recommend you have a machinist measure the block's deck height, and also CC the combustion chaimbers. That will let you figure out what the compression is, as well as tell you how close the pistons will be to the deck. The only true way to check valve clearance is to clay the motor. Use the middle layer of an old HG, lightly torque the head down, and turn the crank while a valve is fully open. That will give you the minimum clearance. Just remember to calculate what VTEC will reduce the numbers to, or engage VTEC with air pressure via the method HELMS manuals recommend.
As far as brand names, Cometic is all I'd recommend if you *had* to get a non-OEM HG. However, I'd personally rather see a tighter valve clearance than
Old Oct 16, 2009 | 01:58 AM
blinx9900's Avatar
.120" Thats really thick. That will probably drop you just about 2 points in compression!
Old Oct 16, 2009 | 03:50 AM
96 GSR-T's Avatar
.120" is literally 4 stock gaskets stacked on top of each other, if your motor is hacked that much you need to just start over fresh....
Telling us how many times it was cut is useless info to us, we need amounts that it was cut, .020" off the deck and .010" off the head is not alot, and certainly wouldnt even require .060" worth of headgasket to work.....
As stated above you need to measure everything to determine exactly how much was removed and what your current clearances are.
Old Oct 16, 2009 | 06:08 AM
Muckman's Avatar
Moderator in Chief
Thanks HiProfile thats exactly what I meant. With flat top pistons I couldnt imagine there being piston to valve contact unless you had a large cam. You need to get it measured to know exactly how much was taken off.
Old Oct 16, 2009 | 02:00 PM
EG6 Love's Avatar
whats the process of seeing how much was machined off consist of? i mean how do they do it?
does the block need to be assembled (mine is stroked using an LS crank)
Old Oct 16, 2009 | 02:16 PM
96 GSR-T's Avatar
Both the block and the head have spots where you can take measurments from to determine what has been removed.... here is where you take measurments from a B-Series head (stock is .040") I am not sure of the stock deck thicknesses.
Old Oct 18, 2009 | 03:50 PM
EG6 Love's Avatar
so that low spot in the corner of the head is .040" below the 'deck' of the head in stock form?
is the block also .040"?
Old Oct 18, 2009 | 04:42 PM
96 GSR-T's Avatar
Correct the head is .040"
If you figure that out please let me know
johnzm
Mar 11, 2005 04:19 PM
Lil Corb
Aug 17, 2004 09:58 PM
fredtoast
Feb 16, 2004 10:25 AM
rusted_eyes
Oct 25, 2003 06:54 PM
NightHawkC5
Feb 23, 2003 09:02 PM
