cutting painted bumper to fit IC piping
ok, im posting this topic in the paint and body section also. i wanted some tips and advice from all the people that ended up cutting their PAINTED front bumper to fit the IC piping. I have a 93 hatch that i just boosted and havnt test fitted nor cut my bumper yet and i dont want to mess it up. thanks in advance
Re: cutting painted bumper to fit IC piping
sharpie, painters tape, measuring tape, dremel.
Measure, it, mark it, measure it again...measure it again, tape it, cut it.
try mounting the intercooler closer to the radiator core support. if it's back far enough the piping won't hit the fog light baffles. i made a small threat (my daily), check my sig. it might help
I always like to cut it a little bit at a time, then test fit it, tehn repeat about 20 times. It takes forever but it usually gets the best results. especially if you dont do alot of body work
thanks guys...im a perfectionist, so the measuring multiple times and cutting little by little wont bother me at all.
nonovurbizniz--its a 93 civic bumper and ic i want to say is 24x6x3....
jasoncrashtech--my first thought was to mock it, like you said, as deep as possible, but the piping just wouldnt line up. i had no choice but to mount it flush with the bumper support. it all good though....
Don't use a Dremel tool. Those are for building little boats and doll houses. An air or elecrtic 1/4" die grinder with a 1/2" metal cutting carbide bit will make fast work of the plastic and leave a very smooth edge once you get the hang of it. You can use a belt sander to straighten out and trim the long straight cuts along the top and bottom too.
a buddy of mine had an extra bumper collecting dust in his garage, so i am using that as a mock up bumper to do all of my cuts and what not. so i did use an air grinder with a 3/8 metal carbide blade and it worked great. cut right through it with ease. so far i only cut off the plastic fog light holes and the plastic middle grill piece. i havnt made any of the piping cuts yet, but i'll let you guys know how everything went and i'll try to post some pics
Mikey3000
04-16-2006 10:49 AM
mike1114
01-12-2005 05:42 PM
See Are X
08-17-2004 08:54 PM
