CEL after boost
Old Oct 6, 2009 | 08:37 PM
keoni96764's Avatar
Default CEL after boost
happens mostly uphill sometimes the temp raises and goes down on my 91 accord f22a doesnt happen all the time though. changed timing belt, water pump, radiator cap, coolant temp sensors, thermostat, and did a coolant pressure test. running a open dumptube right now but going to have one made soon. its a sfp manifold so the wastegate is blowing right by the dizzy thinking that mit be it going to check for air bubbles again tomorrow. thanks
Old Oct 7, 2009 | 04:38 AM
crashsvg's Avatar
Default Re: CEL after boost
whats the cell code its throwing?
Old Oct 7, 2009 | 05:28 AM
mangina's Avatar
did you bleed your cooling system?
temp should stay normal. not up and down.
Old Oct 7, 2009 | 10:10 AM
keoni96764's Avatar
when i jump it it shuts off and it i turn the car off it doesnt come on. yeah i bleed the cooling system.
Old Oct 7, 2009 | 11:59 AM
lilpat93accord's Avatar
x2
Old Oct 7, 2009 | 03:05 PM
crashsvg's Avatar
it shuts off? its not suppose shut off.its not even suppose to b started.turn on the ignition then jump the wires/connection.
Old Oct 7, 2009 | 03:15 PM
keoni96764's Avatar
i meant the cel turns off. if its on and i turn the car off it doesnt come back on. so i cant get a code but if i jump it before i turn the car off the cel turns off.
Old Oct 7, 2009 | 07:37 PM
crashsvg's Avatar
OK..listen the code should be stored in the computer even if the car comes off..have u tried just turning on the ignition (without starting) and jump the wires?
the code will disappear when the car turns off but it should be stored in the computer until u rest or pull the fuse for the computer..
and i don't recommend jumping the wires when the car is running.
Old Oct 7, 2009 | 09:04 PM
keoni96764's Avatar
i tried to jump it after the start is turned off but the cel doesnt come on when i jump it after turning the car off. ill try again but i did it before thanks for the help though ill let you know if i found the code. thanks again
Old Oct 8, 2009 | 01:12 PM
Garage 808 Hatch's Avatar
What management system?? Hondata will throw an overheating code, (on its Own) and it is not a stored code
Old Oct 8, 2009 | 08:35 PM
keoni96764's Avatar
^^^ guarantee???? i have a s300 maybe thats it but why is it overheating? i burped the coolant alot already and everything esle is cherry and i dont lose coolant ill try to change the last sensor and burp the coolant 1 more time have to order so it will take a while. are you from hawaii or something? thanks for the replys : )
Old Oct 9, 2009 | 08:11 AM
Going uphill, the car is under load, more load than usual. And often in these cells, some cars that are street tuned, tend to be lean here, or not have enough timing in those cells, causing higher than normal EGT's, causing higher under hood temps, and also if your DP is close to your radiator, will cause it to heat that more aswell. S300 usually throws the overheating code at 220*f ECT.
I'm actually from Oregon, A few of my good friends opened a shop here Called Garage 808, as the 3 of them are originally from Hawaii.
I'd almost bet that is your CEL, just needs a bit more fine tuning, and maybe some exhaust wrap on the DP?
Old Oct 9, 2009 | 08:12 AM
My civic used to do the same thing on hills when it was warm out, added some timing in the lower rpms of the last 3 vacuum columns and first couple boost columns, then retuned the AFR's, never happened again
Old Oct 9, 2009 | 09:41 AM
keoni96764's Avatar
ok ill talk to my tuner we didnt get it street tuned yet only dyno tuned so i think that mit be the case cause my car boggs out under load. i was going to wait till i got my exhaust all on then street tune the car and maybe up the boost. so thanks man : )
Fubar008
12
Mar 21, 2016 05:39 PM
johnny090881
Jan 5, 2010 07:56 PM
keoni96764
Aug 19, 2009 09:41 AM
Utilitarian
Sep 14, 2007 11:20 AM
Nameless Warrior
10
Dec 16, 2006 07:27 AM
