Resistor Box
Old Oct 10, 2009 | 09:30 AM
Bwhit12's Avatar
Default Resistor Box
I have read all the post on the resistor box wiring, but I just want to double check and make sure I am doing this correctly since I am doing it right now. I have already wired the 4 yellow ones from the resistor box to the 4 inkector wires. I just need to wire my red one to one of the 4 remaining wires. Now do I just wire the red one to any of the 4 remaining wires or should I solder the red one to all of them? Also after I solder the red one should I just leave the remaining wires in the dead end plug or take them out and put tape over them.
I need answers quickly!!!
Thanks
Old Oct 10, 2009 | 12:40 PM
Bwhit12's Avatar
Default Re: Resistor Box
Anyone give any input on this so I can run out there and get it done and try and start this car up??
Old Oct 10, 2009 | 12:54 PM
StolenTeg's Avatar
The red wire on the resister box connect to all four yellow wire at the dead end plug and leave it in the plug
Old Oct 10, 2009 | 12:56 PM
Bwhit12's Avatar
so I just simply have to put the red wire into where one of the inkector wires use to go and I am good to go?
Old Oct 10, 2009 | 04:29 PM
boostedcivicsir's Avatar
Mr. Badwrench
4 dead plug wires from injectors, cut them there. 4 wires from injectors, go to the resistor box. tie the other wires together and solder them to the red wire.
https://honda-tech.com/forums/forced-induction-16/official-injector-resistor-box-install-56k-buy-broadband-517274/
Old Oct 11, 2009 | 06:18 AM
Bwhit12's Avatar
I have seen that thread I just did not quit understand what to do on that part. Do you leave the 4 wires you are soldering together in the plug still?
So far I cut the injector wires to the dead plug and soldered them to the 4 black ones from the resistor box.(I just leave the dead ends of the injector wires into that dead end plug?? Correct?) And now that I found that out about the red wire I will solder it to all 4 of the leftover wires.
Old Oct 11, 2009 | 07:12 PM
Bwhit12's Avatar
????? Need to get this car going ASAP!
Old Oct 12, 2009 | 08:13 PM
b16ej8jdm's Avatar
you solder the 4 wires off the dead plug to the four on the resistor box..then the other four you solder into one wire and solder it to the red wire on the resistor box man..check the pics on that thread..you can see it there..let us know how it works
Old Oct 12, 2009 | 09:52 PM
xtegb16x's Avatar
http://www.c-speedracing.com/howto/r...box_wiring.php
Old Oct 13, 2009 | 03:17 PM
Bwhit12's Avatar
I see where I was getting confused at. Thanks for helping me out guys.
Old Oct 13, 2009 | 03:26 PM
b16racereg6's Avatar
grate link gona need this in a few months lol
d15bfi
Sep 28, 2008 10:58 AM
T9U4ReBgO
Dec 4, 2007 12:11 PM
komat
Aug 25, 2007 04:38 PM
93c1sol
Jun 19, 2006 10:08 PM
92hybridAccord
May 6, 2005 03:35 AM
