low compression for turbo
Old Oct 5, 2009 | 04:28 PM
mrbuff91's Avatar
Default low compression for turbo
heyy whats going on i was being told that 9:1 compression is too much for any turbo motors that you gotta use 8:1 or less
Old Oct 5, 2009 | 04:38 PM
Turbo1.6's Avatar
Default Re: low compression for turbo
LOL! whoever told you that must be joking. Do a search and you find a lot of guys on here making good numbers with 9:1 compression ratio. Make sure you get a good tune and you'll be OK.
reboosted's Avatar
9:1 is fine
Old Oct 5, 2009 | 04:55 PM
1DayIllBFast's Avatar
ha stock JDM gsr is 10.6:1
Old Oct 6, 2009 | 12:44 AM
bzyq2001's Avatar
it's not dsm
Old Oct 6, 2009 | 05:02 AM
Schister66's Avatar
Man U FTW
I built the bottom end in my GSR...its running 9.8:1 compression which isn't far off stock. Do us all a favor and avoid taking advice from that person again
Old Oct 6, 2009 | 07:07 AM
MofasterthenUr''s Avatar
lol
Old Oct 6, 2009 | 07:27 AM
miguel329's Avatar
lol thats funny stay away from that guy's advice, and deff dont let him touch your car!
Old Oct 6, 2009 | 11:50 AM
joppe's Avatar
Depends horsepower levels and gas.. I think over 500whp with pump gas, 8:1 might be better to, but i have no experience at tuning this high.. I have tuned stock jdm b16 with 0.8bar and there was some detonation during tuning but we got it solved with walbro and full 3" exhaust and more tuning. With small exhaust, car was detonating at high rpm no matter what... We used pump gas called shell v-power http://en.wikipedia.org/wiki/Shell_V-Power
Old Oct 6, 2009 | 02:57 PM
boostedEF91's Avatar
im at 9.5 making 460. so maybe that guy who told you that just didnt wnat you to have more power than him haha.
Old Oct 6, 2009 | 02:59 PM
also depending on what you want.. higher compression you can run less boost and make the same power as runing low compression at higher boost.. w/e you want will be fine tho.
Old Oct 6, 2009 | 03:32 PM
Schister66's Avatar
Man U FTW
It all boils down to a few things:
1.) Which fuel are you using?
2.) What turbo are you using?
3.) What are your power goals?
4.) Stock or aftermarket sleeves?
5.) What characteristics do you want from the car?
The way i see it, you want to keep your static compression as high as possible without limiting yourself due to one of the above criteria
EKB18BPR3
10
Feb 14, 2007 05:01 AM
lambo95
Dec 20, 2006 09:24 PM
MUGENTYPER
Feb 6, 2002 06:31 AM
immortal
Nov 6, 2001 08:05 AM
