i have started getting things together....but?
Old Oct 5, 2009 | 05:54 AM
killerB16A's Avatar
Default i have started getting things together....but?
this is what i figured so far. i want to see about 300-350 daily but be able to boost to 450-500whp
b18c1 block and head
gsr crank
pauter rods
84mm cp pistons 9.0.1 cr
aebs main studs
golden eagle sleeves
eabs or arp head studs
type r valve train and cams
i dont have a turbo kit yet still thinking about that. i really want a top mount but they are spendy. not sure what turbo i should run. and not sure on engine management. any ideas? what would be a good turbo for my setup? and also this is my dd so i want it to get good gas mileage. i wonder about running a extra set of injector for when im in boost but im not sure on how to set this up. or should i just run 800-1000cc? any advice would be great! this is my first high hp build!
Old Oct 5, 2009 | 06:59 AM
NonovUrbizniz's Avatar
Loved
Default Re: i have started getting things together....but?
With good management you can run out of boost on 800-1000cc injectors (I think 1000's are a little more difficult but still manageable).
I'd go for Hondata S300. Then for your goals I you should be able to get away with one of the pre assembled kits like rev-hard or peakboost or whoever.
You building the engine yourself or no? with the lineup of parts you listed you might as well send it out to Laskey for a full build.
Even with their economy build you can probobly achieve your goals although on the higher end you'd be pushing it.
Old Oct 5, 2009 | 07:10 AM
killerB16A's Avatar
I will be building the engine myself. I am sending the block to GE for the sleeve job. And taking it to a local shop to balance it. I will be blueprinting it myself. I'm just looking for the best bang for the buck on engine management. I fall a bit short on that. Lol
DA9Sleeper
Feb 5, 2012 12:08 PM
mikeaitken
Aug 14, 2007 07:26 AM
ek9tl
13
Apr 14, 2007 09:49 PM
black_ek
Mar 2, 2007 12:49 AM
EK9civicJDM
Jun 30, 2004 08:17 PM
