What happens if my ECU harness doesnt have an A11 wire
So I had an obd2a harness for my 97 civic that was rearended. I have the s300 with boost control which had the solenoid wired into the A11 wire. Well my new car is a 99 which means a different harness. This one doesnt have the wire in the A11 pin. Not really sure what to do
Re: What happens if my ECU harness doesnt have an A11 wire
with out digging to deep into the problem. running an extra wire from where a11 would be to where ever it needs to go is easy. There are plenty of wiring diagrams to match up your pins.
Remove a pin from your old harness and stick it into the Blank A11 spot, if you use a small metal pick you can get into the connector and release the plastic tab that holds the pin in place. It takes some practice but once you figure it out your golden, I have a small box full of spare pins with the wiring still attached for this very reason.
Does your conversion harness have the A11 Pin? I am kind of confused by your post,,,
^Thats the old harness with the solenoid wired in. I have the a11 pulled off to the side
Heres the new one that doesnt have a wire there.
These people are telling you to remove a pin+wire from your old harness, and stick it into the new harness. It's simple, and there are write-ups showing how - google it.
The other thing you can do is look up a complete pin-out diagram, find **** your car doesn't have (but still has wires/pins for), and move the wires from your chassis harness to your conversion harness.
Here's a hint: chances are you can use the knock sensor pin+wire, since s300 won't use that anyways.
haha thanks john but i hope to pull the pin out today and put it in. I still need a feed line my other one broke. Are you tuning it or is derek?
