too much stress on rods?
Old Nov 21, 2001 | 09:43 PM
dohc_Cx's Avatar
New User
Default too much stress on rods?
my friend is going to be getting a b20z, he's going to build up alittle with cams, cam gears, head and fuel stuff,..try to get it around 150-160whp n/a..and then was going to turbo it then leaving the bottom end stock, boosting around 10-12 for short sprints and 5-6 for daily driven..i told that that would be too much on the rods and that they would break..am i right or could stock internals handle that? someone clear this up for me, please?
Old Nov 21, 2001 | 09:48 PM
VaporTrail's Avatar
New User
Default Re: too much stress on rods? (rACEr_b_O_y_)
stockers with rod bolts should be sufficient
Old Nov 22, 2001 | 07:18 AM
DRAGLS's Avatar
I have stock rods and run 16psi. everyday no low boost settings.
Old Nov 22, 2001 | 07:43 AM
rtype11's Avatar
stock rods will hold quite a bit of boost, one bad compresssion stroke and knock will kill the whole motor though. I ran stockers at the track once they held 15psi on c16 fuel.
Old Nov 22, 2001 | 08:52 AM
dohc_Cx's Avatar
New User
Default Re: too much stress on rods? (VaporTrail)
so even with the head and fuel upgrades, the block could still handle boost..man, would this be a killer setup!
Old Nov 22, 2001 | 08:59 AM
TurboInteg95's Avatar
the rods will be fine. you should worry more about pistons at 12 psi.
Old Nov 22, 2001 | 11:07 AM
dohc_Cx's Avatar
New User
Default Re: too much stress on rods? (TurboInteg95)
like what about the pistons? what can happen?
Old Nov 22, 2001 | 01:36 PM
Ben Huynh's Avatar
This can happen:
Old Nov 22, 2001 | 02:26 PM
dohc_Cx's Avatar
New User
Default Re: too much stress on rods? (ben@importparts.com)
damn! that's one f up piston, i guess he will need forge pistons then, huh? well thanks..
Old Nov 24, 2001 | 10:48 AM
dohc_Cx's Avatar
New User
well, he's thinking about getting 62404..i just read that this is not good with boost? but how about in a b20 with boost, will these lose power?
Old Nov 24, 2001 | 10:53 AM
DRAGLS's Avatar
lack of tuning
Old Nov 24, 2001 | 05:02 PM
Zeus's Avatar
Nice piston... I'll see if I can one up you and get a picture of Overboost's MR2 piston from the early-mid 90's... The dish went super-liquid at 534whp and ran down the side of the piston through all the rings... He said with a smile, and I quote, "guess I leaned it out"!
Old Nov 25, 2001 | 02:40 AM
EBCivic's Avatar
stock rods are plenty strong enough.....all is needed are ARP rod bolts....if anything more than 12 psi is going to be used, you might want to think about lower compression pistons and rings to handle the heat
bmiller17
Sep 16, 2006 08:50 AM
dangerranger21
Jul 21, 2006 08:34 AM
Capt. Jimbo McSubipants
Nov 22, 2005 03:50 PM
thehatchninja
Aug 29, 2005 10:44 AM
boostedinteg03
Mar 20, 2003 12:57 PM
