Whatcha think?
Old Nov 16, 2001 | 11:00 AM
TurboT's Avatar
Default Whatcha think?
ok, H22A or b18c1 turbo?
this is in a Teg chassis....
right now i have a b18c1 bored 0.020" over, sleeved, the works...
if i go h22a, i'll do the same...
running on a hondata stage 4b.
Old Nov 16, 2001 | 11:02 AM
Rob03Pro5's Avatar
Default Re: Whatcha think? (TurboT)
If you already have the B18C1, the stick with it. lots of power potential.. if you want an all out race car and can spend the money, go for the H22A.
Old Nov 16, 2001 | 11:06 AM
98hx99b18c's Avatar
Default Re: Whatcha think? (Rob92SC)
Agreed stick to the b18c1
Old Nov 16, 2001 | 11:19 AM
Suprdave's Avatar
Since your ballin' outta control...lemme get that GSR Playboy...
I'll even come pick it up for ya, no charge...
Suprdave
Old Nov 16, 2001 | 11:24 AM
dbman96's Avatar
New User
Default Re: Whatcha think? (Suprdave)
Considering the very poor results most people are getting from boosted H22As I would not touch one with a ten-foot pole.
If anything I would think about maybe a CR-Vtec 2.0/2.1 liter - that would be a monster under boost.
Old Nov 16, 2001 | 11:26 AM
rtype11's Avatar
if you really want the displacement so bad put an LS crank and LS crowers in your B18C, that is a 2.0L and can still rev the frig out of it becasue of squirters and girdle.
Old Nov 16, 2001 | 11:47 AM
TurboT's Avatar
Default Re: Whatcha think? (rtype11)
rtype, does that really work?
Old Nov 16, 2001 | 11:55 AM
boosted3g's Avatar
I think he meant it as a joke. Basicaly you would have an LS dispacement of 1834cc's. Unless the bore was increased the displacement would remain the same.
[Modified by boosted3g, 12:56 PM 11/16/2001]
Old Nov 16, 2001 | 11:57 AM
dbman96's Avatar
New User
Default Re: Whatcha think? (boosted3g)
I HOPE he meant it as a joke.
Old Nov 16, 2001 | 12:03 PM
rtype11's Avatar
No I am pretty serious, but gave snafued details thanks for catching that - use prelude crank and ls rods that will give you 2.0, and use a piston with very low wrist pin and you get 2.2L, I have the actual specs but Im doing my day job now.
Old Nov 16, 2001 | 12:18 PM
GReddySetGO's Avatar
b20 vtec turbo
Old Nov 16, 2001 | 12:19 PM
b18bturbo's Avatar
you mean use a b20a1 crank from the older preludeds correct. Becuz the h22a wont work for sure. But wont that through your rod stroke ratio back to a prelude level which wass *** to begin with.
Old Nov 16, 2001 | 05:29 PM
bigTom's Avatar
Default Re: Whatcha think? (b18bturbo)
h22 crank is much differant from the b-series cranks so no it would not work
Old Nov 16, 2001 | 07:49 PM
maxim's Avatar
Default Re: Whatcha think? (ek9t)
stick with what ya got.
Old Nov 16, 2001 | 09:08 PM
SiR-G96's Avatar
B18c!!
only go with h22 or CR-Vtec if you are going full ***** out and have alot of $!
Old Nov 17, 2001 | 02:29 PM
Dee's Avatar
Dee
Default Re: Whatcha think? (SiR-G96)
Get a set of 84.5mm pistons for the B18C and get it resleeved. I'm gonna enjoy the hell outta my turbo B20C...
The H22A's can build lots of power but w/o a good set of slicks and some serious chasis mods the torque produced will leave you spinning at the line or breaking axles like they were toothpicks.
97dc2ftw
48
Sep 13, 2011 03:58 PM
quicky_hatch12
Nov 30, 2005 01:45 PM
Speed_Racer
Nov 8, 2002 07:29 PM
