blockguard?
Old Nov 18, 2001 | 10:07 PM
SIK IN DA HED's Avatar
New User
Default blockguard?
i see people using blockguards. what exactly does this do? how much do they run?
Old Nov 19, 2001 | 01:33 AM
MiraiZ's Avatar
Default Re: blockguard? (dlplayboy)
Its kind of a gasket like thing that goes into to th waterjackets to stablize the cylinder heads when on under boots..It stops the cylinders from moving or expanding too much under boost..it helps ...a little...but not under a lot of pressure.
Old Nov 19, 2001 | 04:19 AM
Buzzbomb's Avatar
Default Re: blockguard? (MiraiZ)
I think a little more expanded explanation is a metal piece that turns your open deck honda block into a closed deck block. It does stop the tops of the cylinders from moving at high boost / high horsepower, but the key to sucess with these things. They need to be professionally intalled. They need to be welded in and then the block needs to be milled. Otherwise they're probably cause more problems than protection.
Old Nov 19, 2001 | 05:02 AM
meanteg's Avatar
New User
Default Re: blockguard? (Buzzbomb)
How much boost can they handle in a b18c1?
b16bri
Mar 8, 2011 01:45 AM
tobe1424
Aug 16, 2005 10:11 AM
CANTFAZZDISCHIT
Jul 9, 2004 07:18 PM
Dr Pooface
Dec 3, 2003 10:53 AM
D-SPEED
Sep 16, 2001 09:34 PM
