What Pistons for LS motor???
I just got in on those eagle rods and now I wanted to know what pistons I should use for my turbo LS motor... I was told that JE doesn't make pistons for it unless you get them custom and I could get SRP's but haven't heard anything good about them....I wanted to keep the compression stock...so which pistons are recommended by those with LS-turboed cars
Re: What Pistons for LS motor??? (civictom)
if you can wait just ask JE to make you a set and copy the dimensional specs from the SRP's, just keep in mind that the JE alloy expands at a different rate.
for street go 9.0 for race only 8.5:1
If you need SRPs pistons I have a set I just took out of my motor today. They were used for aroud 6K miles and they seem to hold up well. I boosted 22psi with no problems. If your interested or need more info give me a shout at Boosted3gaol.com. First 100 bucks takes them
Re: What Pistons for LS motor??? (millertime)
They are the standard 81mm size. I now have a 84.5mm bore so these are no use to me. Other than the fact that they are dirty and have a few small scratches on the sides they are fine. I will also include the wrist pins and spiral locks with them. Also they are 9.2:1 compresssion ratio.
Re: What Pistons for LS motor??? (97 JDM LS DC2)
So how much boost can the SRP pistons 9-2-1 handle ....I've heard that no more than 15lbs is recommended but then I've also heard as much as you want pretty much as long as its tuned properly..
GusRock77
Honda S2000
16
03-01-2005 12:24 PM
