Build up for moderate boost
Old Nov 22, 2001 | 01:56 PM
Bert1's Avatar
Default Build up for moderate boost
Hello all,
I'm pretty sure I bent some valves today on my NA set-up, so I'm thinking I'll lightly build the bottom ond when I have the stock head put back on. How much power could I safely handle with pistons, rods and a blockguard? Is a blockguard fairly easy to install with the head off but the bottom end still in the car? I'd like to be able to run mid 13's on streets... could this set-up handle it?
Thanks,
Old Nov 22, 2001 | 02:07 PM
Etylorcen's Avatar
Default Re: Build up for moderate boost (Bert1)
What kind of motor?
Old Nov 22, 2001 | 02:38 PM
Bert1's Avatar
Default Re: Build up for moderate boost (Etylorcen)
Sorry, I forgot this was on my second username without a sig. This would be on my 98 GSR with stock B18C1 head and block (except for the psions/rods/blockguard to be added.) I already have the Moroso oil pan and GReddy oil cooler installed and 270cc injectors (from NA set up) but nothing else I can think of that would a difference.
Thanks
Old Nov 22, 2001 | 03:22 PM
D-Man's Avatar
dont use the block guard..you dont need that for 13s.
Old Nov 22, 2001 | 05:10 PM
Bert1's Avatar
Default Re: Build up for moderate boost (D-Man)
Is there a reason not to use it besides the cost of the block guard itself? I have head they can comprimise cooling. I was just thinking it would provide an extra margin of safety and would be basically free to install since the head is going to have to come off anyways.
Old Nov 22, 2001 | 05:18 PM
ben_vtec's Avatar
New User
enlighten me...what is a blockgaurd?
Old Nov 22, 2001 | 06:17 PM
D-Man's Avatar
its not a good idea to install the block guard like that, cause once you tap it in,it can distort the cylinder bore which will really Fuc things up,the right way to install it would be to disassemble the engine,install block guard,then hone or bore cylinder out but like i said,you dont need it for 13s.
Bert1's Avatar
Default Re: Build up for moderate boost (ben_vtec)
Well, I'm obviously no FI expert, but as I understand it a blockguard is typically a piece of aluminum that fits around the sleeves inside the block and prevents excessive flexing which can occur in a high performance application using an open deck design.
Old Nov 22, 2001 | 06:21 PM
Bert1's Avatar
Point taken. If a correct install requires complete disassembly then it is out. What type of engine management would be required for 13's on street tires? How about fuel delivery? Will stock injectors or my 270's be sufficient?
Thanks so much for you help!
Old Nov 22, 2001 | 06:32 PM
D-Man's Avatar
Stock ECU should be fine along with a Rev Hard Turbo kit w/intercooler,which should include Fuel Pump..it might be a good idea to step up to 310cc injector to be on the safe side
[Modified by D-Man, 3:32 AM 11/23/2001]
Old Nov 22, 2001 | 06:43 PM
Bert1's Avatar
Would I idle acceptably with the stock ecu, 310's and Rev Hard kit? I idled very poorly after I got the 270's until I got chip reprogram, after which I could usually avoid stalling if I left the interior fan on but still didn't idle anywhere near perfectly. Thanks agina for the advice!
jedi anvil
May 24, 2011 06:00 PM
sh4mr0ck
Dec 28, 2008 09:56 PM
methos713
May 30, 2008 07:26 AM
RedTegLS
Mar 20, 2004 09:03 AM
arctic-k20
Sep 9, 2003 09:29 AM
