Coolant issues!
Old Nov 21, 2001 | 05:18 AM
whagkangmakulet's Avatar
Default Coolant issues!
My coolant bottle overflows when I boost a lot.. and usually cause my Temp guage to go up. I really dont like this.. I'm pretty sure everybody does. Does changing the radiator cap helps or removing the thremostats?
I know I remember seeing this topic before..can someone forward me to it.. THANKS!
Old Nov 21, 2001 | 05:49 AM
KekeK-18's Avatar
Default Re: Coolant issues! (whagkangmakulet)
Are coolant spitting out of the reservor and engine over heat while running high boost? I'm 99% sure you have a blown or leaky head gasket. The only way the fix that is to change your head gasket.
Old Nov 21, 2001 | 06:08 AM
GSRacer's Avatar
New User
Default Re: Coolant issues! (b18cturbo)
i second that
Old Nov 21, 2001 | 06:12 AM
my reservoir goes up only after running 9lbs of continuos boost, then when i shutdown my engine and check it for a couple of hours ..it goes back to the height of coolant level. I'm not smoking out or any sort of burning coolant. I believe it has something to do with coolant pressure, especially under boost. When I run NA everything is OK.
Old Nov 21, 2001 | 06:30 AM
immortal's Avatar
Banned
my head gasket blew after these symptoms after about 2 weeks.
Old Nov 21, 2001 | 06:43 AM
KekeK-18's Avatar
You definitely have a leak headgasket, not being seal properly. What happens is when you run high boost the the pressure lift the head and coolant are being force back causing it to overflow and cant circulate...cause the engine to over heat. but when you let go and drive it normal (less pressure), the gasket will be ok and return to normal. Are you running an aftermarket head gasket?
Old Nov 21, 2001 | 07:08 AM
immortal's Avatar
Banned
that makes PERFECT sense (about lifting head up etc) as to how mine acted....
Old Nov 21, 2001 | 07:12 AM
yes I do have a Greddy 2MM head gasket. Is there a solution for me here? If you have a bad Head Gasket..you would be loosing some coolant right? ever since I rebuilt my engine.. I never re-tight my head studs...Is it too late? Would a thicker gasket causes all this issue?
[Modified by whagkangmakulet, 4:39 PM 11/21/2001]
Old Nov 21, 2001 | 04:39 PM
anyone? can thick head gasket cause this? should I get a aftermarket radiator cap helps?
Old Nov 21, 2001 | 06:19 PM
Incognito's Avatar
I'm having similar problems. One of a few things happened. Your head lifted, head gasket blew out, warped the head or warped the block. Chances are it's the head lifting or your head gasket died. If I were you, I'd try to retorque the head first, then do a leakdown test (force compressed air into each cylinder individually at TDC with the radiator cap off and look for bubbles). If you don't get bubbles, you're good to go. If you do get bubbles, you're assed out. Head has to come off then. Good luck.
krc91987
Jun 28, 2015 03:51 AM
PatiKTP
Mar 9, 2007 11:20 AM
BlackCRX
Mar 8, 2005 07:58 AM
Alstare
Jul 27, 2004 04:06 AM
ghettocrxsi
Oct 29, 2003 02:11 PM
