greddy turbo kit questions
will a greedy turbo kit set at 7 psi yeild the same amount of power output as a drag III kit set a 7psi. And how much boost could you get out of a greddy kit. Thanks for the help!
New User
Re: greddy turbo kit questions (Integra187)
The DragIII comes with a front mount intercooler. I don't think the Greddy kit does. The FMIC should make a difference.
the greddy and drag kits have different power curves. greddy has more midrange, drag more top end. i like the greddy fuel managemnt solution better becasue they use larger injectors and a piggyback computer as opposed to a RRR or other such fuel pressure raising devices. you can do a search on this topic, it has been discussed extensively already.
ya i been lookin around at a whole bunch of old post to get more info. but couldnt find an exact answer to the question about 7psi drag vs 7psi greddy.
[Modified by Integra187, 8:47 PM 11/17/2001]
Setup idedentically, the DRAG will yeild a higher top end, the GReddy will have a flatter power curve. Ultimatley though, the DRAG will probably out gain the GReddy, especially as the psi's go up..
i think the drag would be higher hp, but remeber that its not all about #'s. its about what you want to do with it...and how much of that hp is usable. like the vortech civic at 272 hp....at the redline! almoset useless!!!
fake mugen power
03-22-2005 02:04 PM
Integra187
11-24-2001 08:19 PM
