Fuel/computer setup
Old Nov 16, 2001 | 03:21 PM
jamal-188's Avatar
Default Fuel/computer setup
Okay I was planning on getting a drag III kit and just running 9psi on stock internals but I think I came across a good deal on eagle rods and JE pistons sooooo I think I'll get and install now so when I get my turbo I can boost maybe like 15psi daily? My questions are will 550's be big enough injectors, and what's the cheapest but effective way to run my fuel/ignition? This turbo setup is really draining the account!!! BTW 01 GSR.
Old Nov 16, 2001 | 04:28 PM
GSRacer's Avatar
New User
Default Re: Fuel/computer setup (jamal-188)
from my understanding if you go with 550's, you have to go standalone. i was told that the highest you could go is 370's tuned via V-AFC.
Old Nov 16, 2001 | 05:26 PM
bigTom's Avatar
Default Re: Fuel/computer setup (GSRacer)
550's is the limit of injector size a stock ecu can handle... with of course some sort of computer to lean them out
Old Nov 16, 2001 | 05:32 PM
DRAGLS's Avatar
afc will idle the 550 but if you want a good idle go w/ 440
Old Nov 16, 2001 | 07:00 PM
jamal-188's Avatar
Default Re: Fuel/computer setup (DRAGLS)
Will 440's deliver enough fuel for like 15psi? I think that would be around 335-350hp?
Old Nov 17, 2001 | 06:11 AM
Drboosted's Avatar
New User
370'S WITH AN AFC WILL RUN 17 POUNDS IF TUNED CORRECTLY. I RUN 15 POUNDS ALL DAY LONG AND HAVE NO PROBLEMS.
11.8@117
Old Nov 17, 2001 | 09:21 AM
DRAGLS's Avatar
yes 440 are enough to support 15 psi on a drag kit I currently run 440 at 16psi in a integra
Old Nov 17, 2001 | 11:22 AM
jamal-188's Avatar
What fuel tunning devices are you guys using afc's??
Old Nov 17, 2001 | 11:27 AM
DRAGLS's Avatar
I am using the s-afc w/ a cartech regulator
Old Nov 17, 2001 | 01:10 PM
VTC_CiViC's Avatar
I'm usuing a set of 440's with AFC trim on my D16 @8-9psi.
Old Nov 17, 2001 | 01:30 PM
CM-R's Avatar
Default Re: Fuel/computer setup (VTC_CiViC)
Can i use the apexi' V-AFC with 440cc injectors and 4:1 fmu disk? Or do i have to get 370cc?....
Old Nov 17, 2001 | 04:45 PM
DRAGLS's Avatar
Default Re: Fuel/computer setup (CM-R)
Hey if you are going to spend the money on new injectors u might as well get the 440, so if u ever build up the bottom end you can go up as 18psi and you won't have to upgrade your fuel setup again.
Old Nov 17, 2001 | 05:20 PM
Reverend's Avatar
Default Re: Fuel/computer setup (Drboosted)
11.8@117
Traction problems?
Old Nov 17, 2001 | 06:55 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: Fuel/computer setup (Reverend)
i use stock ecu 12:1 fmu,440cc injectors,a venom 100gph pump and made 434whp at about 20 lbs of boost.
Old Nov 17, 2001 | 07:13 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: Fuel/computer setup (turbotypeR)
Jesus...... that's gotta be one fast Type-r
Old Nov 17, 2001 | 09:59 PM
paulzy's Avatar
Default Re: Fuel/computer setup (ForcedAccord)
just get the 550's and get the new greddy e-manage...cheap and great
Old Nov 17, 2001 | 10:41 PM
DLB1994's Avatar
how can u run a 12:1 fmu with 440cc injectors at 20psi of boost that would make 240psi of fuel at the fuel rail thats know way in hell the fuel pump cant pump that much fuel and u would be rich rich rich as hell
more like a 4:1 disk in the fmu
Old Nov 17, 2001 | 10:49 PM
dustin's Avatar
Default Re: Fuel/computer setup (DLB1994)
Ok, whoever the all-caps guru is up there that says you can run 370s @ 17psi, some sort of rising rate regulator is required. 370cc injectors cannot provide enough fuel for even 10psi boost @ 40psi static fuel pressure.
Dustin
Old Nov 18, 2001 | 01:32 AM
jamal-188's Avatar
Default Re: Fuel/computer setup (dustin)
Anybody know anything about the new greddy e-manage? How does it compare to the V-afc which is about the same price?
Old Nov 18, 2001 | 05:40 PM
25 Year Member
the fuel pressure only goes as high as the pump will pump it-no,it does not go to 240 psi.the set-up works,trust me.
Old Nov 19, 2001 | 04:41 AM
jamal-188's Avatar
So I think I"ll go w/ the 440's and try to tune them w/ a V-afc or maybe the new greddy system once I get more info on it. Does this sound good?
[Modified by jamal-188, 1:41 PM 11/19/2001]
Old Nov 19, 2001 | 05:10 AM
meanteg's Avatar
New User
When you say the new Greddy e-manage, Aye you talkin' about the new blue box, that is a kind of adjustable fcu?
[Modified by meanteg, 2:11 PM 11/19/2001]
Old Nov 19, 2001 | 06:01 AM
VTC_CiViC's Avatar
Default Re: Fuel/computer setup (meanteg)
The GReddy E-manage is like a step up from the base FCU that comes with GReddy kits. Allows you to interact with the software and dial it in as you see fit. Rather go with a true standalone like Hondata or AEM EMS personally if I'd went with a motor build etc..
NXAccordTO4B
Nov 19, 2003 12:12 PM
revhigh96
Mar 2, 2003 07:17 PM
rrei
Jan 27, 2003 10:27 AM
swpdb16
Oct 30, 2002 09:48 PM
