Should i be getting any boost in 1st gear? I only get maybe 2-3psi.. Turbo LS
New User
I was always under the impression that I shouldnt be boosting any in first gear but now I am not so sure. I am running 9psi on a Turbo LS. I also use tial wastegate and profec b.. not sure if that matters.. Any Idea why I am not if I am supposed to be?
Re: Should i be getting any boost in 1st gear? I only get maybe 2-3psi.. Turbo LS (Damon501)
your supposed to be....at least I know i can hit full boost in first at about 4k
Re: Should i be getting any boost in 1st gear? I only get maybe 2-3psi.. Turbo LS (dustin)
i guess i hit full boost after 4k in 1st gear cause after 4k the tires break loose
Re: Should i be getting any boost in 1st gear? I only get maybe 2-3psi.. Turbo LS (Ray)
Yup boost in first gear sucks....too much power. Pretty sick tho having enuff power for your tires to break loose, but sucks for acceleration.
New User
Re: Should i be getting any boost in 1st gear? I only get maybe 2-3psi.. Turbo LS (Etylorcen)
Any opinions on why I dont reach boost in 1st gear?? What could be wrong in my set up??
New User
Wouldnt I be losing boost in other gears if it were the hoses??
You might be making enough pressure in the other gears to overcome it.
