NEED TO BUILT UP ENGINE... again.
Old Nov 16, 2001 | 04:30 PM
wonny's Avatar
Default NEED TO BUILT UP ENGINE... again.
Hello everyone. Last time I posted I was just about to get a turbo installed in my car (Integra LS 97). Now I'm posting because I need to rebuild the engine that blew up.
Here is what I need to know.
My turbo might be damaged. I'm sending it back to REVHARD to have it checked out. It was loose so the shop I'm at now thinks that it is broken. There might be particles in it. But, is a rebuilt turbo reliable? It is a t3/t4. How much does it typically cost to rebuild a turbo?
Thanks everyone in advance.
Old Nov 16, 2001 | 05:25 PM
bigTom's Avatar
Default Re: NEED TO BUILT UP ENGINE... again. (wonny)
take the housings on the turbo off and check the wheels out... how much play is there in the shaft?
Old Nov 18, 2001 | 06:11 PM
wonny's Avatar
Default Re: NEED TO BUILT UP ENGINE... again. (ek9t)
I just went to see the car. My engine came in and I'm just waiting on the tranny.
As for the turbine, there is a little play on the shaft. The fan on the compressor side jiggles a little (maybe 1 cm or something like that - very small yet noticeable). I'm having it sent out and redone by turbotecnics.
Update:
I'm waiting on the internals for later. I'm just getting my engine and boosting at 7lbs daily and 10 racing. I have upgraded the torque converter to level ten.
Payce.
Old Nov 18, 2001 | 06:51 PM
bigTom's Avatar
did u check the wheels or not?! dont waste ur money sending it out if there is nothing wrong with it... take off the compressor housing and the exhuats housing and at least take a look
Old Nov 19, 2001 | 05:42 AM
wonny's Avatar
there was oil leaking from the turbine, the seals are shot. I'm just having those redone.
EJ8 944
Jun 16, 2008 06:47 AM
-mk2turbo-
Dec 24, 2006 12:00 PM
mrx
Oct 19, 2005 11:28 AM
mr_mbuna
Sep 8, 2002 11:41 AM
92HB_HB
Jan 25, 2002 10:38 AM
