to vtec or not to vtec....
Old Nov 20, 2001 | 07:24 AM
xJ.SLOTHx's Avatar
Default to vtec or not to vtec....
ok this is the situation, ive made up my mind and im planning on joining the darkside,but i still have a few questions. i have an 88 crx si and i plan on getting a dragIII kit or maybe the RH st-2 kit. but my question is , would you throw a b16 in the car or an ls, given that both motors would be built. ive done a search but there really isnt anything comparing these both. what would be the pros and cons of each. i know the ls would yield more torque and the b16 would rev higher etc....but i need some input from people who have these setups first hand. thanks a lot.
Old Nov 20, 2001 | 07:34 AM
4dGSR at work's Avatar
Default Re: to vtec or not to vtec.... (ian)
I SAY LS PORTED
strong block...
vtec aint all that...
cheaper...
cleaner boosting... ( me wastegate dumps out when vtec hits sometimes)
this could just be me but...
vtec you do satrt w/ higher hp output but it is about torque
Old Nov 21, 2001 | 04:11 PM
ITRbroham's Avatar
shit post warrior
Default Re: to vtec or not to vtec.... (4dGSR at work)
Are there any more stock B18A/B's around? Dayum.... I haven't seen one that wasn't turned into a LS/VTEC in a long time! I'm thinkin' that if you could find one that this swap would be much easier, cheaper, and more torque than the B16A setup!
Old Nov 21, 2001 | 10:27 PM
DIRep972's Avatar
Smarter than you
I vote for LS..
Old Nov 21, 2001 | 10:59 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: to vtec or not to vtec.... (DIRep972)
Vtec+Boost doesn't mean it's better! Would go w/out the Vtec personally, just my .02
Old Nov 22, 2001 | 06:51 AM
maxim's Avatar
Default Re: to vtec or not to vtec.... (ForcedAccord)
B18b would be my pick.
Old Nov 22, 2001 | 07:09 AM
DRAGLS's Avatar
Man if u are going to spend the money on a new engine go w/ the v-tec engine if u don't u will regret it down the road. I have a ls and it sucks.
Old Nov 22, 2001 | 07:19 AM
maxim's Avatar
Default Re: to vtec or not to vtec.... (DRAGLS)
What's wrong with it? How much boost are you running?
Old Nov 22, 2001 | 07:24 AM
DRAGLS's Avatar
Default Re: to vtec or not to vtec.... (maxim)
I am running 16 pounds on a drag kit tuned by sfp I want that sick top end v-tecs have on boost
Old Nov 22, 2001 | 07:47 AM
DIRep972's Avatar
Smarter than you
typeR head and then you get to rebuild your turbo to new specs for top end and your set!
but i still think in a debate between the B16a and the B18B id choose B18B a million times
[Modified by DIRep972, 4:48 PM 11/22/2001]
Old Nov 22, 2001 | 09:07 AM
xJ.SLOTHx's Avatar
thanks for the replies guys...and for the b18b not having top end.....its a matter of building it i.e. block girdle, new bearings etc...with a good valve train etc... and you'll be up there with the rest of em'
Old Nov 22, 2001 | 12:27 PM
ITRbroham's Avatar
shit post warrior
Please whatever you do have it tuned right because I am so sick and tired of hearing folks who just slap on turbos and end up destroying their motor because they havent had it tuned properly! And then they have nerve enough to blame it on the manufacturer or the person they bought it from!
Old Nov 22, 2001 | 12:36 PM
DIRep972's Avatar
Smarter than you
Default Re: to vtec or not to vtec.... (ITRbroham)
How do u tune a car running a bolt on turbo kit and an FMU?
Old Nov 22, 2001 | 12:43 PM
Ray's Avatar
Ray
New User
do you guys have any dyno #s for a B20b/z Turbo(no-vtec)? Cause im also not sure if i wanna build my ls head or swap a vtec later on.
Old Nov 22, 2001 | 01:11 PM
ITRbroham's Avatar
shit post warrior
Well something's not tuned right if the motor runs like **** after u install the bolt on turbo kit and an FMU!
Old Nov 22, 2001 | 01:24 PM
PureTeg420's Avatar
just get a turbo with bigger specs if you want an insane topend. Vtec is an extra 20 hp, that is not going to give you a "sick top end".
And you need some kind of fuel controller or cam gears if you want to tune. The only thing you could do to an integra with just a turbo kit is set back the timing a couple degrees..
Old Nov 22, 2001 | 01:29 PM
Ray's Avatar
Ray
New User
Default Re: to vtec or not to vtec.... (PureTeg420)
vtec only makes 20hp? hmm i thought it was more like 50+hp
Old Nov 22, 2001 | 01:30 PM
lazyvietboi's Avatar
Default Re: to vtec or not to vtec.... (Ray)
some one try going to the dyno and test it out. one run w/vtec another run w/o vtec.
just a thought.
Old Nov 22, 2001 | 01:38 PM
Ray's Avatar
Ray
New User
Default Re: to vtec or not to vtec.... (lazyvietboi)
i mean look at the hp of a LS to a LS/vtec the hp numbers oh those are already 40+hp and with the higher hp base, you'll get a ever bigger gain when you turbo it.
Old Nov 22, 2001 | 02:32 PM
DRAGLS's Avatar
Mine is tuned in really good for its setup:
s-afc
s-itc
cartech fmu
profec-b
rc 440 injectors
Old Nov 22, 2001 | 02:52 PM
DIRep972's Avatar
Smarter than you
whats not gonna be tuned right? theres nothing to tune when u bolt on a regular turbo kit.. you can change ignition timing and thats about it.. The only reason a car would run like **** after u bolt on a turbo kit is if a part in the kit was defective or the install was done wrong.. and therefore u should blame the manufactuer or the installer..
Old Nov 22, 2001 | 09:15 PM
ITRbroham's Avatar
shit post warrior
I guess! I'm an all motor man myself!
Old Nov 23, 2001 | 09:15 AM
Flamenco-T's Avatar
FVK VTEC, WHO NEEDS VTEC WHEN YOU HAVE BOOST....
PS: caps is intentional...
Old Nov 23, 2001 | 01:40 PM
PureTeg420's Avatar
When i said 20 hp from vtec, i meant 20 hp more off a b16a then a b18b. But the loss of torque is gonna be like 50+ if you choose the si engine....stick with LS
Old Nov 24, 2001 | 02:00 PM
Ray's Avatar
Ray
New User
I see, but I think we have been comparing a LS vs a LS/Vtec.
[Modified by Ray, 11:01 PM 11/24/2001]
chargedek
Dec 22, 2005 04:27 PM
GOLDBERG
31
Dec 21, 2004 06:41 PM
ilovevtec
Jun 29, 2004 02:22 PM
WiLLMaTiX
Apr 12, 2004 03:59 PM
92B18Bvx
18
Apr 5, 2004 08:28 PM
