burnt pistons
Old Nov 19, 2001 | 08:56 AM
bQQsted hybrid's Avatar
Default burnt pistons
What causes burnt pistons, and are there any major problems of having them? The reason I'm asking is...I pulled my motor apart to change the rings, and noticed that the pistons were burnt. They are JE 9:1 pistons and there's no way Im buying another set.
Old Nov 19, 2001 | 09:00 AM
Rob03Pro5's Avatar
Default Re: burnt pistons (bQQsted hybrid)
Are you sure it's not just carbon on top of the pistons? Is it on all the pistons?
Old Nov 19, 2001 | 09:07 AM
rtype11's Avatar
the carbon raises the cr a bit and doesnt really hurt untill it stars blocking valves, use some HD degreaser and they will look new again
Old Nov 19, 2001 | 11:53 AM
John_at_J&S's Avatar
Check out the SafeGuard knock controller: http://www.safeguard.20m.com
If you have time, here are some threads about burned pistons from an MR2 forum.
http://www.board.mr2faq.com/showthre...ighlight=J%26S http://www.board.mr2faq.com/showthre...ighlight=J%26S
Old Nov 19, 2001 | 12:01 PM
DirtyLude's Avatar
Default Re: burnt pistons (John at J&S)
Describe what you mean. Is it black carbon deposits or does the piston top look slightly brown and burnt like?
Old Nov 19, 2001 | 12:24 PM
Default Re: burnt pistons (DirtyLude)
The machine shop cleaned the pistons to the best of their abilities. I know the difference between carbon buildup and burnt pistons . I was worried because I know that the carbon deposits could just be cleaned off, but when a piston is burnt, there's nothing you can do (as far as I know).
Old Nov 19, 2001 | 12:47 PM
dbman96's Avatar
New User
What causes pistons to burn is generally running too lean, possibly detonation, possibly excessively retarded ignition.
Old Nov 20, 2001 | 09:53 AM
earl's Avatar
Default Re: burnt pistons (dbman96)
As long as the pistons have not warped or changed dimensions you are ok but find out why the pistons are discoloring (too lean or detonation) and FIX the problem.
Old Nov 20, 2001 | 10:15 AM
bigTom's Avatar
Default Re: burnt pistons (earl)
if the piston is not in perfect form... i wouldnt use it... just scrap them... u can get new ones for 500
Old Nov 20, 2001 | 12:17 PM
SiR Kid's Avatar
New User
Default Re: burnt pistons (ek9t)
THIS is a burnt piston.
[Modified by SiR Kid, 3:19 PM 11/20/2001]
Old Nov 20, 2001 | 12:24 PM
VaporTrail's Avatar
New User
Default Re: burnt pistons (SiR Kid)
good kill!
Old Nov 20, 2001 | 12:34 PM
Liltrix's Avatar
U were running lean. U melted a part of the piston, just to make sure check Ur Injectors and make sure the fuel and air is mixing properly. Send them to RC for a good cleaning.
Rob03Pro5's Avatar
Default Re: burnt pistons (VaporTrail)
D A N G .
Old Nov 20, 2001 | 12:42 PM
SiR Kid's Avatar
New User
Default Re: burnt pistons (Rob92SC)
That's stock LS pistons in a B16a, with stock injectors trying desperately to run 11 psi with only a 6:1 Vortech Fuel Pressurizer
Didn't work too well.
LS pistons for the record in a B16a net a compression ratio of about 8.3:1, and they have valve clearance issues to boot. Notice the nice shiny crecent moons on the outer edge of the valve reliefs. NEVER make this mistake, PLEASE!
[Modified by SiR Kid, 3:44 PM 11/20/2001]
gcsd3742
Jul 19, 2010 02:36 PM
hotimportcrx
Sep 15, 2005 10:13 PM
