quick question on Greddy turbo timer...
Old Nov 17, 2001 | 07:45 PM
Flamenco-T's Avatar
Default quick question on Greddy turbo timer...
since integra has 2 ignitions wires,
which wires from the timer (green and blue) do I tap in (IGN1 or IGN2) ?
thanks
Old Nov 17, 2001 | 11:05 PM
Flamenco-T's Avatar
Default Re: quick question on Greddy turbo timer... (Flamenco-T)
come on guys, I know there a lot of you guys running timer...
Old Nov 17, 2001 | 11:25 PM
b18bvudoo's Avatar
New User
ign1
edit: on my blitz timer green goes to ign1 and blue goes to acc
[Modified by vudoo666, 12:27 AM 11/18/2001]
Old Nov 17, 2001 | 11:27 PM
Flamenco-T's Avatar
Default Re: quick question on Greddy turbo timer... (vudoo666)
thanks, but there are two wires (green and blue) that I need to connect to both IGN 1 and IGN 2...
I need to know which goes to which...
tia
Old Nov 17, 2001 | 11:30 PM
b18bvudoo's Avatar
New User
o ok, read my edit..i'm assuming all timers are similar...btw i read yor dyno post, good stuff
Old Nov 17, 2001 | 11:31 PM
Flamenco-T's Avatar
thanks on the dyno...
my greddy timer has four wires, red (constant 12v power), black( ground) and these grees and blue for IGN1 and IGN2....
I think I am gonna try Green for ign1 and the blue for Ign 2
BTW, it says that I need to connect the green wire to the Ignition that DOES NOT drop voltage when the strater is activated, so can I safely assume IGN 1 does not drop voltage when starter is engage ?
stan
[Modified by Flamenco-T, 12:34 AM 11/18/2001]
Old Nov 17, 2001 | 11:33 PM
b18bvudoo's Avatar
New User
blue goes to ACC not ign2
Old Nov 17, 2001 | 11:36 PM
Flamenco-T's Avatar
hmmm, I'll try that tomorrow, I don;t think it really matters about IGN 2 or accesory though.....
anyone care to correct me ?
Old Nov 17, 2001 | 11:42 PM
b18bvudoo's Avatar
New User
you prolly right, but thats how mines is hooked up and it works fine
dam, maybe shoulda used im...
Old Nov 18, 2001 | 12:01 AM
Arturbo's Avatar
Better than steak
25 Year Member
Go buy a test light and find out for sure...
art
Old Nov 18, 2001 | 12:42 AM
Lei Siew Long's Avatar
yes both ignition wires matter. i did this install for my fifth gen civic with alarm a while back so, i don't remember which color wires are ignition 1 and ignition 2. but, i'll try my best to help you.
i'm assuming the wires for the fifth gen civic and third gen integra are the same since they share the same chassis. so, here it goes, the blue wire from the timer goes to the solid yellow wire on the ignition and the green wire on the timer goes to the black/yellow wire. hope this helps. if not, i suggest looking in the helms or haynes manual for the correct wire.
Old Nov 18, 2001 | 06:49 AM
JM Performance's Avatar
Default Re: quick question on Greddy turbo timer... (boostedeg6)
http://www.greddy.com/technical/TurboTimer_Frame.htm <right here
Psychoteen101
Audio / Security / Video
May 12, 2009 08:43 AM
8dxhatchy8
Feb 1, 2009 11:44 AM
crxvtecturbo
Jan 22, 2005 03:26 PM
BOOSTEDCIVICD16
Jan 29, 2004 04:56 PM
1hottEG6
Jun 1, 2002 08:11 PM
