JE high comp pistons
Old Nov 16, 2001 | 04:30 PM
Si_leeper's Avatar
Default JE high comp pistons
are JE b16a 10.5 compression pistons to high for a turbo setup? i dont plan to boost more then 16 psi.
Old Nov 16, 2001 | 04:31 PM
GSRacer's Avatar
New User
Default Re: JE high comp pistons (Si_leeper)
16 psi w/ 10.5 to 1 comp??? WHAT???
Old Nov 16, 2001 | 05:16 PM
dbman96's Avatar
New User
Default Re: JE high comp pistons (GSRacer)
No, I think that would almost certainly spell doom for your engine.
Old Nov 16, 2001 | 05:23 PM
bigTom's Avatar
Default Re: JE high comp pistons (dbman96)
sounds good to me... just u have to make sure u tune it correctly
Old Nov 16, 2001 | 06:17 PM
FAST94GSR's Avatar
New User
Default Re: JE high comp pistons (ek9t)
it can be done but man i'd resleeve that motor if i were you. and also I wouldn't do it without a standalone ecu.
Otherwise just go with 9:1
Old Nov 17, 2001 | 12:07 AM
Si_leeper's Avatar
whats the highest psi i can boost on 10.5 comp JE pistons?
Old Nov 17, 2001 | 08:15 AM
bigTom's Avatar
over 30 if done right
Old Nov 17, 2001 | 08:22 AM
AshlandSi's Avatar
I'm going to run 11:1 with 12-16psi. But then again, my block is at Golden Eagle being introduced to Godzilla
NotAJDMFanBoy
Apr 14, 2012 10:49 PM
supracharger19
10
Mar 18, 2010 04:13 PM
Rob97'SH
Oct 17, 2009 05:14 PM
Nace325e
May 5, 2009 12:45 AM
SupaTeg
Dec 23, 2002 10:22 PM
