Boost with high compression....who's tried it?
Old Nov 15, 2001 | 04:01 PM
AshlandSi's Avatar
Default Boost with high compression....who's tried it?
Since I'm having my block sleeved and will be running Hondata, I'm tempted to give it a try. Maybe keep the boost down around 8-10psi. Dumb idea or worth a shot on a built block?
(Like 10.5:1 or 11:1)
Old Nov 15, 2001 | 04:41 PM
Dee's Avatar
Dee
Default Re: Boost with high compression....who's tried it? (AshlandSi)
I am running Stock JDM GSR 10.6:1 compression but only until my block gets back from Golden Eagle.. As long as you run a conservatively fat (rich) mixture you shouldn't have any problems!
Old Nov 15, 2001 | 04:46 PM
dustin's Avatar
Default Re: Boost with high compression....who's tried it? (drealgsr)
viren is running 10.0:1 I believe @ 30psi or so. as long as fuel and ignition timing are in check you should be ok.
Old Nov 15, 2001 | 04:49 PM
BoostinDC2's Avatar
Default Re: Boost with high compression....who's tried it? (dustin)
yeah i have a built motor and im running 10:1 also
Old Nov 15, 2001 | 05:01 PM
AshlandSi's Avatar
Default Re: Boost with high compression....who's tried it? (BoostinDC2)
Cool, I think I'm going to give it a try No reason to spend all this money on reinforcing the block if I'm not going to throw the kitchen sink at it.
Old Nov 15, 2001 | 05:29 PM
b18bturbo's Avatar
its all about your tuning high compression motors make more pwr with ease if tuned right,
nikko_SOHC
Jun 2, 2009 07:56 PM
SRL
Jul 10, 2003 08:47 AM
94TealGSR
Feb 8, 2003 08:39 AM
gigantor
May 22, 2002 02:53 PM
B18CHatch
Oct 18, 2001 03:06 PM
