anyone wanna take bets?
Old Nov 22, 2001 | 03:47 PM
DIRep972's Avatar
Smarter than you
Default anyone wanna take bets?
heres my set up:
Revhard stage 2 kit
tial wastegate, bosch inline fuel pump
everything else is stock
heres whats next:
ACT heavy Duty(hope it holds up)
thermal 3"
skunk2 IM
hondata w/ 550's
Walbro intank
114octane race gas
17-18psi
on a stock LS motor
hopefully about 350whp is acheiveable.. ill probably start building up a block after that but how long u think it will last? assuming I dont blow it before i get that far
Old Nov 22, 2001 | 03:50 PM
D-Man's Avatar
Default Re: anyone wanna take bets? (DIRep972)
if you got a bosch pump already,why do you want a walbro?
Old Nov 22, 2001 | 03:51 PM
ForcedAccord's Avatar
Texas B*tch!
17-18 PSI on a stock engine.. isn't that a lot, unless they made the LS blocks differently.
Old Nov 22, 2001 | 03:53 PM
LsTurbo91's Avatar
heres my set up:
Revhard stage 2 kit
heres whats next:
thermal 3"
skunk2 IM
hondata w/ 550's
Walbro intank
114octane race gas
17-18psi
on a stock LS motor
I'll be right behind you with 15psi on 440's
Old Nov 22, 2001 | 03:54 PM
DIRep972's Avatar
Smarter than you
Default Re: anyone wanna take bets? (D-Man)
I may use both in conjuction or ill dump the inline and just use the intank when I go hondata
Old Nov 22, 2001 | 03:57 PM
DIRep972's Avatar
Smarter than you
Default Re: anyone wanna take bets? (ForcedAccord)
yeh it is alot, I just want to see if it can be done..
Old Nov 22, 2001 | 04:06 PM
D-Man's Avatar
dont use the walbro,,its a so so pump..the bosch is a lot better,,also the bosch pumps out 300lph vs the 255lph for the walbro..mount the bosch in the tank if you want,if it fits,if it dont get that shortened ENDYN bosch pump,itll fit..also bosch makes a big pump with a 18mm inlet..it flows 370lph...thats what i got instead of going with a noisy 500lph Aeromotive/Patxon pump
itspools
Aug 8, 2011 02:22 AM
AMLS4dr200whp
Aug 18, 2005 07:14 AM
jfoster
Nov 2, 2004 03:52 AM
sneakypete
Jul 27, 2003 10:01 AM
flip1199
Aug 18, 2002 12:31 PM
