Coolant overflow bottle.....
Old Nov 18, 2001 | 02:59 PM
Incognito's Avatar
Default Coolant overflow bottle.....
Can somebody please tell me exactly what the coolant overflow bottle does, and what actually happens. Is coolant supposed to come out of the cooling system into the overflow bottle, or the other way around? What happens after that? Is it supposed to get sucked back in eventually, or spit back out? If so, when does this happen, and how much of the coolant actually goes back in or out?
Old Nov 18, 2001 | 03:26 PM
98hx99b18c's Avatar
Default Re: Coolant overflow bottle..... (Incognito)
Pretty much as the name says, usually when you start overheating to a certain point the fluid will overflow into the coolant overflow.
Old Nov 18, 2001 | 05:35 PM
Incognito's Avatar
Default Re: Coolant overflow bottle..... (98hx99b18c)
So if the car doesn't overheat, coolant should never enter or leave the overflow bottle?
Old Nov 19, 2001 | 03:39 AM
Mista Bone's Avatar
D Tranny Guru
As the coolant heats up, it expands. Once the pressure exceeds you rad. caps spring, excess air/coolant goes into the overflow bottle. As engine cools back down the coolant inside the engine contracts and sucks back in coolant from overflow bottle.
If you car overheats badly or blows a headgasket, excess pressure will go straight to the overflow bottle and cause ALOT of bubbles/burps.
GeneBEllis
May 10, 2013 05:44 PM
95dc2teg
Sep 24, 2007 08:15 PM
tallyBanned
Aug 18, 2006 08:50 AM
msmithgsr2131
Feb 19, 2006 08:39 PM
Pat
Jan 27, 2002 05:12 PM
