JB Weld
Old Nov 19, 2001 | 07:41 PM
93LSivic's Avatar
Default JB Weld
Do you think this is good stuff for intercoolers? On my starion I/C I had a small hole in one of the flat pieces that go from tank to tank. I put the JB weld to fill it and it seems to have dont the trick. Although I havent put my turbo kit in so I cant test it. I also need to have the piping placement moved to the sides of the end tanks as opposed to stock location on the top.
Do you guys think I can JB weld the new pipes into the sides of it? And also JB weld the blocker plates to cover where I cut the factory pipes at. This **** is pretty stong and says can hold something like 1437 psi or something like that. I dont see how the measly 6-12 psi I will run through it will leak or blow out of it.
All of this because of the budget kit im doing. I plan on upgrading in the future though.........
Old Nov 19, 2001 | 07:44 PM
Smashback's Avatar
Default Re: JB Weld (93LSivic)
I know a guy that JB welded on his BOV flange and never had problems. I used it to "weld" the oil return to my oil pan.
Old Nov 19, 2001 | 08:33 PM
turbocoupe's Avatar
yup it works...I had the same problem.. . just be generous with the JB.
Old Nov 19, 2001 | 08:52 PM
Pritos's Avatar
New User
JB Weld is spiffy stuff!
For my Bov flange I just spot welded the piping together and 'sealed' it with the jb. No problems so far for over a year at 12psi.
Old Nov 19, 2001 | 09:15 PM
Smashback's Avatar
Default Re: JB Weld (Pritos)
Hey .. it's Manny! Pritos is the guy with the JB Welded BOV flange I was referring to!
I got a 66 Dodge Dart way back when that I swapped a 360 SB into. I had to drive it for several months while I was doing all the work while it still had the 225 slant 6 in it. The sixer had a monster crack along one of the coolant tunnels, and I JB Welded that sucker too. It took almost two packs of it, but it held strong for months until I swapped the engine!
Old Nov 19, 2001 | 10:52 PM
93LSivic's Avatar
Default Re: JB Weld (mplex2000)
Thanks for everyones responses. Now for another question. In regards to the metal i will use for the piping and plates on the IC. Since im not welding it, just basically "glueing" it, then the JB weld wont care that i am using 2 differnt metals will it?
Seems like a stupid question, but I dont want any problems. ****, if I can do all this, then theres no need for anykind of welding--except the downpipe. This means I can save a little more money, woo hoo!!
Old Nov 19, 2001 | 11:33 PM
Smashback's Avatar
Right, you can JB Weld some wood on there even ... but that's probably not a good idea
Old Nov 20, 2001 | 05:10 AM
rtype11's Avatar
Even though I do not agree with some of the applications you have found for JB I will let you in on a product that is even better - its called "Cold Weld" package is the same but all black background, it is much stronger when dry than JB, costs the same.
Old Nov 20, 2001 | 07:07 PM
Pritos's Avatar
New User
Default just get a grinder
and really roughen up the 2 surfaces so the jb will have a good grip. I dont see why jb couldn't hold 2 diff metals together.
[Modified by Pritos, 8:07 PM 11/20/2001]
Old Nov 20, 2001 | 08:51 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: just get a grinder (Pritos)
JB Weld is some of the baddest stuff ever made, it's the **** Cheers to JB Weld.
Old Nov 20, 2001 | 10:53 PM
InfamousRS's Avatar
Default Re: just get a grinder (ForcedAccord)
When I had my Ranger, before I bought my teg, I tor the interior all up for my stereo. It was really stupid of me. Anyways, I used like 7 packages of JB Quick and 3 packs of JB Weld to put it all back together!!!! Anyways, it worked great! Then on my teg, my friend gave me a striped out B & M shift ****, so I JB welded it to my shift lever, let me tell you, I think Im going to have to cut my shift lever in half to get the **** off when I put a short shift in! JB Weld Works great!!!!!!
Ash J. Williams
Nov 8, 2012 08:44 AM
IOwNaHoNdA
Aug 25, 2008 03:39 AM
trentepic
May 11, 2005 08:12 PM
Andyb22g
Nov 16, 2004 06:36 PM
BlackB18CTeg
May 6, 2003 12:48 PM
