fuel line for wet nitrous kit
I need to build a fuel line for my friends kit. a couple questions, what kind of fitting do i need to connect to an NX fuel 'noid? 4AN right?
then we need to tap the top of the fuel filter... the car is a 95 DX what kind of fitting can I use to tap that? I pulled the little bolt off the top of the big bolt and it looks really small... is there a middle bolt in there? help me out guys, i want to have this running by saturday at the latest, preferably tomorrow.
D Tranny Guru
Re: fuel line for wet nitrous kit (Safir)
why not get a 3/8" fuel gauge tee fitting. Then you could run a #4 line off it using a #4-1/8"NPT adapter.
#720-2975 in Jegs catalog. Any decent V8 spped shop will have them in stock. I just cut into the rubber fuel in between the filter and fuel rail. I used it to mount a fuel pressure gauge under the hood to check FPR settings.
doing a zex wet kit, and im wondering where the fuel line is that i need to tap already seacrhed ...
TABIAS
11-29-2003 12:29 PM
