SCE Copper Pro Headgaskets?
Old Nov 19, 2001 | 08:14 PM
AshlandSi's Avatar
Default SCE Copper Pro Headgaskets?
Opinions?
http://www.scegaskets.com/asianSearch_IE4.asp
Old Nov 20, 2001 | 05:21 AM
rtype11's Avatar
Default Re: SCE Copper Pro Headgaskets? (AshlandSi)
i run them with O-rings, you have to change them every so often, so unless you are prepared to O-ring and replace every 5k do not use them. otherwise they almost guarantee that your head will not lift. they only cost 50 anyway, O-ringing is like 100 and the wire should cost 5, you will need a special sealant like Hylomar or permatex orange.
Old Nov 20, 2001 | 06:36 AM
AshlandSi's Avatar
Default Re: SCE Copper Pro Headgaskets? (rtype11)
Could a step-decked sleeve be used instead of the o-rings?
Old Nov 20, 2001 | 07:06 AM
rtype11's Avatar
not sure, dont think that it will create the same cruch seal as the aircraft wire, I use 0.043 wire, half goes into head, half goes into crushing the gasket - its more PSI of sealing power than the width of the sleeve you are using. wait for some more replies maybe someone tried it out already.
Old Nov 20, 2001 | 09:45 AM
earl's Avatar
Some shops install thir sleeves .002 above the deck to act like an o-ring. Wouldn't try it with a steel shim head gasket but would work with sandwich style. I personally use the o-rings but either way works.
Earl
Old Nov 21, 2001 | 01:11 PM
AshlandSi's Avatar
Default Re: SCE Copper Pro Headgaskets? (earl)
Thanks for the opinions.
I'm having my sleeves stepped so I guess this headgasket option is out.
eg:R
Feb 24, 2015 10:53 AM
mintef
Apr 23, 2006 07:19 AM
H20too
Oct 23, 2005 02:58 PM
1genmud
Sep 20, 2003 06:01 PM
turboex
Jan 24, 2003 08:07 PM
