running stock fuel pump and boosting...is this ok?
Old Nov 18, 2001 | 06:20 PM
turbocoupe's Avatar
Default running stock fuel pump and boosting...is this ok?
I've had my turbo on for 3 weeks now I have been boosting without an inline...I've seen alot of posts that say not to boost without it...why not?
Old Nov 18, 2001 | 06:28 PM
D-Man's Avatar
Default Re: running stock fuel pump and boosting...is this ok? (turbocoupe)
you can get away with boosting about 7-8psi with stock pump.any higher..pump cant keep up with fuel demand..leaning the motor out and possibly blowing the engine
Old Nov 18, 2001 | 06:56 PM
turbocoupe's Avatar
Default Re: running stock fuel pump and boosting...is this ok? (D-Man)
that would suck. My inlne is on it's way...thanks to Brian (turbointeg95) just curious if I can boost and get away with it. . .I think i'll chill out till it gets here....
[Modified by turbocoupe, 9:57 PM 11/18/2001]
Old Nov 18, 2001 | 07:19 PM
shamoo's Avatar
Will you make something up for me please?
Hmm, I wouldn't if I were you. I was boosting for a while, not knowing that my inline pump wasn't on. My EGT temps were way high, indicating a pretty lean mixture. It was around 1450F or so.
Tomakit from HT helped me out with that, and now the temps hover around 1200F even boosting like a madman.
Incidentally, Tom pulled my plugs for a compression test and noticed piston shavings on it....probably from my boosting without the proper fuel.
Mr.Death
Jun 22, 2005 01:12 PM
Nick7
Oct 21, 2004 07:17 AM
switchblade
Apr 24, 2004 02:07 PM
W.Zero
Dec 12, 2002 03:08 PM
