Max boost efficiency on drag3's IC
Old Nov 21, 2001 | 09:12 PM
Etylorcen's Avatar
Default Max boost efficiency on drag3's IC
I was wondering what is the max boost you can run with drag3's ic and still have it be efficient enough so upgrading isnt nessessary.
Old Nov 22, 2001 | 07:21 AM
DRAGLS's Avatar
Default Re: Max boost efficiency on drag3's IC (Etylorcen)
I have always wondered that myself, I currently run 16psi on the drag core, does anyone know (proven)
Old Nov 22, 2001 | 08:08 AM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: Max boost efficiency on drag3's IC (DRAGLS)
my car made 380whp on the drag ic at 20 lbs of boost.however,i changed it to an apexi gtr core and made another 50hp(same boost) at a more conservative air/fuel ratio.spool up is much better now as well.when i first installed it i did not change anything on the boost controller and boost was still climing hard at 25lbs. when i let off.
Old Nov 22, 2001 | 11:04 AM
93LSivic's Avatar
Default Re: Max boost efficiency on drag3's IC (turbotypeR)
Damn bro whats up with those times?? What were you diong drag racing in the rain
Sounds like someone needs some big slicks
Old Nov 22, 2001 | 02:05 PM
Etylorcen's Avatar
Default Re: Max boost efficiency on drag3's IC (93LSivic)
HP #'s dont mean anything if you can't put it to the ground. There are 1000whp supras that runs 11's cuz they have so much torque they can't help but slip all over the place.
Respect Given Non Takin
Aug 21, 2008 07:47 AM
ochsy03
Mar 24, 2005 08:53 AM
turbopanda
May 24, 2002 01:42 PM
'94gsR
Oct 9, 2001 12:47 PM
GSR_Dude
Sep 20, 2001 12:41 PM
