ohhhhhhhhhhhhh what a day!
Old Nov 17, 2001 | 04:37 PM
DIRep972's Avatar
Smarter than you
Default ohhhhhhhhhhhhh what a day!
so as u probably read earlier, me, flamenco and jbsadler all went to the dyno today.. I went there not expecting much cause I am just running the .3bar spring in my wastegate.. I got on the dyno and my car only made 140whp with 135lbs of torque....
I was pissed, wtf u know I was at least expecting around 160.. The guys at alamo told me its cause I was running 2" exhaust(im ordering thermal monday) but I knew that couldnt be the only problem.. i am not running boost gauges yet so I was thinking it could be a boost leak or pressure drop in the intercooler since i was at such low boost..
Then I started to be worried, maybe I have a fucked up motor so I went to jbsadlers place and we did a compression test, it went 220, 210, 220, 220 so that was good.. I was happy then but we still didnt know the problem.. Then we looked to the BOV... Yup, all my boost was leaking out the BOV.. It was way too loose and my wastegate wasnt even opening after the turbo would spool.. So we tightened that up(btw vortech BOV's are hard as **** to tune) and I think we found the medium between boost leak and compressor surge..
We took it out to test it and I have to say the butt dyno thinks its making alot more power now since it breaks the tires loose at higher RPMs in first.. So im alot happier now then I was at 3:00 and im gonna get that thermal on there and go back to the dyno in two weeks when I have boost control and gauges... wish me luck
[Modified by DIRep972, 1:38 AM 11/18/2001]
Old Nov 17, 2001 | 06:22 PM
tararan's Avatar
Default Re: ohhhhhhhhhhhhh what a day! (DIRep972)
whatr is this? gsr i assume? goodluck....
Old Nov 17, 2001 | 06:30 PM
TurboInteg95's Avatar
the 3 inch exhaust will make a big difference.
Old Nov 17, 2001 | 06:48 PM
GruvyTune's Avatar
New User
something is wrong, my 95 GSR made over 175 no boost and 210 with 6 psi and tuned.
Old Nov 17, 2001 | 06:54 PM
D-Man's Avatar
Default Re: ohhhhhhhhhhhhh what a day! (GruvyTune)
damn..those are pretty sad HP numbers..you sure your turbo aint seized
Old Nov 17, 2001 | 08:15 PM
PureTeg420's Avatar
Default Re: ohhhhhhhhhhhhh what a day! (D-Man)
if your running stock exhaust, stock cat you should have just disconnected the cat while you were there and did the pull. But if you get a highflow cat or testpipe with that thermal you will probably get close to 30whp gain.
Old Nov 17, 2001 | 08:18 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: ohhhhhhhhhhhhh what a day! (PureTeg420)
Dont worry chris, we'll figure it out. I'll make sure of it...
art
Old Nov 17, 2001 | 10:27 PM
Flamenco-T's Avatar
Default Re: ohhhhhhhhhhhhh what a day! (Arturbo)
Yep, you can always call me anytime man....
Old Nov 17, 2001 | 11:39 PM
DIRep972's Avatar
Smarter than you
what u mean by my turbo being seized? I know those are sad numbers thats why I was pissed..but tonight at the street races I pulled on 2 mid 14sec cars so I know my ***** gained alot of power since we fixed the boost leak.. one car was a riced out GSR with nitrous and the other was a GTP grand prix running 11lbs on his supercharger..
but ill go back to the dyno with the thermal and 8lbs of boost and I garuntee ill make over 200 no problem.. maybe more
[Modified by DIRep972, 8:40 AM 11/18/2001]
Old Nov 17, 2001 | 11:53 PM
Arturbo's Avatar
Better than steak
25 Year Member
Yes you will...
Old Nov 18, 2001 | 06:42 AM
D-Man's Avatar
what i meant by siezed is that the bearing might be fucked up on your turbo..causing too much friction,slowing it down..ive seen turbo's that where totally seized..you look at the impeller while the engine is running..it aint moving..car still drives and all.but it aint got no power.
Old Nov 18, 2001 | 08:03 AM
DIRep972's Avatar
Smarter than you
oh well thats not the problem, I had a big *** boost leak and I garuntee thats the problem..
jacob4lester
Feb 7, 2010 09:51 AM
BDaTurboTeg
Oct 1, 2006 07:43 AM
siis2fast
Aug 28, 2005 08:21 PM
Smashback
Jul 11, 2002 08:49 PM
