Downpipe Fabricating Problems
Old Aug 26, 2004 | 03:52 PM
aalb1's Avatar
Default Downpipe Fabricating Problems
I brought my car to the shop to get a Downpipe fabbed up for it. These are the headers that I have and I was told they are AC compatible with a 2.5" downpipe.
I got a call from the shop saying that it is too tight of a fit to be effective. He told me that clearance between the exhaust housing and the AC Compressor is 2.75". The 5-bolt flange is a quarter-inch itself and doing the math that leaves no room for any bend. I told him I'll give him a call in the morning and this is where I am banking on my HT buddies for help.
This is what I thought about so far...
1. Turn the turbo around. But this means I won't be running an air filter.
2. Tell the shop to snuggle it in. But this means it may not be effecient at all. This is a picture of what I think it might look like with similiar headers maybe even worse!
Any other ideas? I need to make a decision tomorrow.
Modified by aalb1 at 5:39 PM 8/26/2004
Old Aug 26, 2004 | 04:28 PM
Bambooseven's Avatar
turn it around and worry about the filter later, charge piping will be easier that way too.
Old Aug 26, 2004 | 04:37 PM
project dc2's Avatar
Default Re: Downpipe Fabricating Problems (aalb1)
he said he wantred to keep AC, well ive seen the manifold myself and i think its almost impossible, but synik on here build one 2.5 ac compatible so i guess it is, esp if you have a 5 bolt housing.
Old Aug 26, 2004 | 04:44 PM
aalb1's Avatar
Default Re: Downpipe Fabricating Problems (project dc2)
Come to think of it would a t4 compressor housing even clear the AC compressor?
Old Aug 26, 2004 | 06:45 PM
This One's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aalb1 &raquo;</TD></TR><TR><TD CLASS="quote">Come to think of it would a t4 compressor housing even clear the AC compressor?
You wont be able to fit the turbo the opposite way and retain A/C
Only thing that you could do is cheat the pipe like in the picture, Its not very effiecient but you gotta do what you gotta do......
Old Aug 26, 2004 | 06:51 PM
aalb1's Avatar
Does anyone have other pictures of downpipes and their angle needed in clearing the ac housing?
Old Aug 26, 2004 | 07:11 PM
This One's Avatar
That not for your manifold, but What you asked...
Old Aug 26, 2004 | 07:21 PM
aalb1's Avatar
Default Re: Downpipe Fabricating Problems (This One)
no way does my manifold give me that much room.
So you guys think i should just give it a real acute angle?
Or suck it up and lose the AC? I live in NJ and you need the AC all year around.
Modified by aalb1 at 8:49 PM 8/26/2004
Old Aug 26, 2004 | 09:01 PM
Bailhatch's Avatar
no AC and put the compressor on the drivers side . Best setup for several reasons; better DP flow because there are no 'cheater' cuts and there are fewer degrees of direction change. Also the oil return line is not forced to cross the DP and charge pipe. Much cleaner and you can put a filter right on the inlet if you want. You don't NEED the AC but i'm sure it's nice. Just boost everywhere and the wind will cool you off
Old Sep 3, 2004 | 09:16 PM
deeweewoo's Avatar
I had the same problem with the same manifold and I just fabricated my own downpipe and ported it really well and it works great. Give me your email and I will send you some pics.
Modified by deeweewoo at 9:12 AM 9/4/2004
ZhaGg
Jul 12, 2004 10:38 AM
hackish
Apr 27, 2004 08:09 AM
tegmech
Aug 4, 2003 04:27 PM
DC2R714
Mar 7, 2002 12:31 PM
