Pulling out timing and how much?
Old Aug 26, 2004 | 01:36 PM
Turbowa's Avatar
Default Pulling out timing and how much?
I'm sure this has been talked about and its prob. a very general question. But how much timing should you pull out for X amout of boost. Or does it really depend on if your detinating to begine with? For example .5-1.0 degrees of timing out per lb at say 15lb's of boost on pump gas (93 octain)? Or is this to broad of a question to answer?
Old Aug 26, 2004 | 01:46 PM
ms1motorsports's Avatar
Default Re: Pulling out timing and how much? (Turbowa)
There really isn't a base amount of timing to pull compared to boost becasue each motor is different. There are too many variables to determine when a motor will detonate. If your not detonating then give more timing until you feel slight amounts and then back off. Just be very careful when doing this as blowing a motor will be very easy. Just be very conservative and you'll be fine.
Old Aug 27, 2004 | 06:08 AM
Turbowa's Avatar
Thats what I thought. Thanks.
mikej94civex
Nov 9, 2009 05:06 AM
93civciv
Dec 4, 2007 05:23 PM
bmm89
Nov 21, 2004 08:17 PM
Btothe3rdDegree
Nov 12, 2004 04:53 PM
b00stedbyFastrax
Sep 1, 2002 06:39 AM
