TurboXS Standard and High Performance BC differences in spool times?
i'm currently running a TurboXS standard manual boost controller at around 13psi..would switching to the High Performance one make a difference in spool times?
has anyone had experience with the two?
Re: TurboXS Standard and High Performance BC differences in spool times? (LudEcrous)
I would say no b/c your boost controller has nothing to do with how fast your turbo spools. All it does it tells your wastegate when to open and close.
Re: TurboXS Standard and High Performance BC differences in spool times? (underpressure02)
A checkball type controller keeps the wastegate from seeing any boost until the desired pressure is reached. Without it the wastegate will open up a little bit early when it sees partial boost, increasing spool time.
hybridcrx
07-23-2002 08:07 AM
