Boost Problem
Old Aug 25, 2004 | 07:09 PM
Sprayin_civic's Avatar
Default Boost Problem
OK well I have a problem with the boost gauge not reading vac and boost. It reads one or the other. but not both. Can anyone give me some advice as to why its doing this?? Also the boost gauge only will go to 4psi. I tried my friends boost gauge and nothing same result so its not the boost gauge. all hardpipes are secure. no exhaust leaks either. Anyone want to take a guess as to whats wrong?
Here are some pics of my setup.
Old Aug 25, 2004 | 07:14 PM
EJ1 wilcox's Avatar
Default Re: Boost Problem (Sprayin_civic)
I'm not sure if I understand the problem correctly...so, the gauge reads vac but not boost? But it reads up to 4psi? What does it read at idle?
Are you sure your wastegate isn't opening at 4psi? If you hooked up another boost gauge and it read that you were boosting 4psi maybe your wastegate is your problem...
Is your wastegate internal or external?
Old Aug 25, 2004 | 07:18 PM
Default Re: Boost Problem (EJ1 wilcox)
well the way i hjave it hooked up right now it reads only boost and not vac. and it only goes to 4psi. I cranked up my Hallman Boost Controller and stil only goes to 4psi. Internal Wastegate as well
Old Aug 26, 2004 | 12:07 AM
bump anyone got any advice?
Old Aug 26, 2004 | 12:16 AM
eg6T's Avatar
Default Re: (Sprayin_civic)
what pound spring(bar?) in the wastegate?
Old Aug 26, 2004 | 01:11 AM
it says the wastegate should open at 7psi
Old Aug 26, 2004 | 01:21 AM
eg6T's Avatar
what kind of wastegate and do u know for sure its 7 psi..people **** up.
Old Aug 26, 2004 | 10:35 AM
here is who i bought the turbo from. https://honda-tech.com/zerothread?id=840638
dan_w_82
Mar 28, 2006 11:37 AM
StolenTeg
Mar 17, 2006 10:41 AM
cajnatc
Jun 13, 2003 04:18 AM
Kamin
Sep 11, 2002 08:46 PM
