water wetter does it work?
Old Aug 27, 2004 | 11:53 AM
ek_99_SiR's Avatar
Default water wetter does it work?
is it worth buying?
Old Aug 27, 2004 | 11:58 AM
pngfolife's Avatar
Default Re: water wetter does it work? (1.6i-16zc)
Works best if you use a 70/30 mix of water/antifreeze. It just incesases the heat transfer coefficient of the water.
Old Aug 27, 2004 | 12:01 PM
ek_99_SiR's Avatar
Default Re: water wetter does it work? (pngfolife)
ya i did the 70/30 i was just wondering if it made it run any cooler? im gonna hot wire my fan to run all the time on a switch
Old Aug 27, 2004 | 01:11 PM
smurfey002's Avatar
i dumped the whole bottle in my radiator. seemed to run a lil cooler. but i doubt it made much of a difference, i have since changed my radiator fluid.
Old Aug 30, 2004 | 12:54 AM
pngfolife's Avatar
You probably won't notice any temperature difference according to your gauge, but the stuff does work. Maybe on cold nights you may see some change.
Old Aug 30, 2004 | 01:03 AM
ATS*Mark's Avatar
OG triple OG
it works ok , but what works better is if you put a drop or 2 of liquid hand soap in there.....does the same thing as watter wetter , but better , and is alot cheaper since you prolly have it in your house right now. and now im not joking.
Old Aug 30, 2004 | 07:37 PM
Icey112's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">it works ok , but what works better is if you put a drop or 2 of liquid hand soap in there.....does the same thing as watter wetter , but better , and is alot cheaper since you prolly have it in your house right now. and now im not joking.</TD></TR></TABLE>i heard the same thing im going to try it tonight
Old Aug 30, 2004 | 08:24 PM
david_rg79's Avatar
Default Re: water wetter does it work? (Icey112)
I'm required to run it...once you hit the 12's and 11's they make you run waterwetter and water only
Old Aug 30, 2004 | 08:47 PM
hybrid93SIvic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6i-16zc &raquo;</TD></TR><TR><TD CLASS="quote">ya i did the 70/30 i was just wondering if it made it run any cooler? im gonna hot wire my fan to run all the time on a switch </TD></TR></TABLE>
instead of wiring it up to a switch just wire it up to your ignition so when you turn the power on it turns on...a switch is forgetfull somtimes
Old Aug 30, 2004 | 08:52 PM
ATS*Mark's Avatar
OG triple OG
Default Re: water wetter does it work? (hybrid93SIvic)
just jump your fan switch , it will turn on whenever the ignition key is turned
ATS*Mark's Avatar
OG triple OG
Default Re: water wetter does it work? (david_rg79)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david_rg79 &raquo;</TD></TR><TR><TD CLASS="quote">I'm required to run it...once you hit the 12's and 11's they make you run waterwetter and water only</TD></TR></TABLE>
nhra doesnt allow coolant.
Old Aug 30, 2004 | 09:27 PM
buda18's Avatar
Default Re: water wetter does it work? (Hella_JDM)
dang are you serious? ive never heard about this
so just put a drop or two or liquid hand soap in the radiator along with 50/50 water/anitfreeze mixture and you're set?
Obama
31
Jun 25, 2007 12:39 PM
ALMXDUPINTEGRA
Jun 19, 2007 04:27 PM
Joeyt426
Jul 28, 2006 04:28 PM
redlinex
Dec 25, 2003 08:50 AM
MyWhiteCivic
Oct 11, 2002 02:53 PM
