safe whp?
Old Aug 26, 2004 | 12:23 PM
markvqwerty's Avatar
Default safe whp?
Whats a safe whp goal on a stock b16a2?(changed clutch good air\fuel and no detonation)
thanks in advance!
Old Aug 26, 2004 | 12:59 PM
Boostage's Avatar
Default Re: safe whp? (markvqwerty)
220whp is safe and very noticeable over stock
Old Aug 26, 2004 | 01:40 PM
donkiman's Avatar
i wouldnt really go above 260 on stock block but its been done. 220 is very conservative, but safe.
Old Aug 26, 2004 | 08:59 PM
22psicrx's Avatar
Default Re: safe whp? (donkiman)
8lbs of boost tuned 240whp is sweet
Old Aug 26, 2004 | 09:05 PM
11psiTurboSI's Avatar
Default Re: safe whp? (22psicrx)
240-260hp I'd say is safe... I've seen 300hp, but I wouldn't go that high with stock pistons and being a daily driver
Old Aug 27, 2004 | 02:45 AM
dnbruut's Avatar
Default Re: safe whp? (9psiTurboSI)
so 240 would be very safe???
Old Aug 27, 2004 | 05:43 AM
Default Re: safe whp? (dnbruut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dnbruut &raquo;</TD></TR><TR><TD CLASS="quote">so 240 would be very safe???</TD></TR></TABLE>
tuned... yes!
Old Aug 27, 2004 | 06:54 AM
EFbomb's Avatar
its nice to see someone finally asking the right questions
4u
Old Aug 27, 2004 | 07:55 AM
dnbruut's Avatar
Default Re: safe whp? (SBD)
well im not stupid, i just dont have a lot of experience!
Old Aug 27, 2004 | 09:44 AM
99B16Si's Avatar
most of the time youll here the great question "how much boost can i run?" when boost isnt really the relevent factor. i ran my stock b16a2 on 9psi on a revhard kit for about a year with zero problems untuned with an fmu and 310cc injectors and it finally gave out when i got greedy and turned it to 10psi (back in the dumbass days).
but to answer your question....with all the fuel mamagement systems out there now there is no reason to even attempt running some shitty fmu. get yourself a good computer(hondata, aem, uberdata, etc.)... keep the air fuel mixture rich(~11.5:1) and the timing conservative(around 21-23deg of total timing) and you can push 250-275whp safely. on most off the shelf kits this will require about 9-10psi
Old Aug 27, 2004 | 03:59 PM
dnbruut's Avatar
Default Re: safe whp? (99B16Si)
im not going off the shelf kits, im going t3t4 and i know its about tuning and hp and not about psi.
first i wil go with a dyno and a afc with dsm and a lot of retard @ the dizzy then i will go with uberdata or something like that.
97grnrs
Jan 6, 2008 07:07 PM
89civicsiB18B
May 14, 2005 07:56 AM
B18 CYA
Apr 7, 2004 03:43 PM
Turbo-Si
Mar 6, 2004 10:14 PM
Wrath of VTEC
Sep 15, 2003 06:58 PM
