delsolb16a2 where is the fuelpump relay???
Old Aug 26, 2004 | 12:30 PM
markvqwerty's Avatar
Default delsolb16a2 where is the fuelpump relay???
im having problems with my fuelpump relay and i cant find it???? the only relay i can find is the main relay.
Thanks in advance!
Old Aug 26, 2004 | 12:41 PM
Del_Slowest's Avatar
Default Re: delsolb16a2 where is the fuelpump relay??? (markvqwerty)
near the hood release lever
Old Aug 27, 2004 | 02:48 AM
dnbruut's Avatar
Default Re: delsolb16a2 where is the fuelpump relay??? (Del_Slowest)
is it inside the main relay?
thanks!
Old Aug 27, 2004 | 08:18 AM
dnbruut's Avatar
Default Re: delsolb16a2 where is the fuelpump relay??? (dnbruut)
anybody????
Old Aug 27, 2004 | 08:29 AM
len's Avatar
len
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dnbruut &raquo;</TD></TR><TR><TD CLASS="quote">is it inside the main relay?
thanks!</TD></TR></TABLE>
The main relay IS the fuel pump [main] relay.
Old Aug 27, 2004 | 08:33 AM
Default Re: delsolb16a2 where is the fuelpump relay??? (len)
the main relay gives power to the ecu and to the fuel pump. I would check your grounds just to make sure. I thought my relay was bad but turns out it was a ground that i was missing.
Old Aug 27, 2004 | 08:52 AM
dnbruut's Avatar
sorry didnt know honda has got one main relay that gives power for both.
im pretty sure its the relay cause it wont start ones in a while and than ill have to try it several times.
sometimes i can hear the pump when i turn the ignition on and it stops after a few sec.(i know thats normal) then i start the engine(no pump sound or voltage when the eng. is running) and after a few sec it stals.
im afraid its going to be a expensive relay then!
turbocivic1984
Jun 29, 2008 09:59 AM
EG6LS
May 22, 2006 09:30 PM
DnB TeK
Jun 22, 2005 02:46 PM
C8V6C
Jan 20, 2005 09:46 PM
PoonHunter
May 15, 2003 02:00 PM
